Installation & Licensing
Unable to retrieve license from NLM on Ubuntu
11 REPLIES 11
Message 1 of 12
ChrisJanes1578
846 Views, 11 Replies
The box that my previous NLM was running on has died (a windows machine), so I've transferred to another server that's running ubuntu (I've grabbed an updated lic file with the new machines hostname / mac address too). Everything seems to be running fine on the new machine, but the client's can't connect to retrieve a license.
Here's the successful bootup of lgmrd:
14:44:05 (adskflex) Server started on games-server for:
14:44:05 (adskflex) 85520ESEC_F (consisting of: 85619ESEC_2011_0F
14:44:05 (adskflex) 85519ESEC_2010_0F)
14:44:05 (adskflex) 85529MAYAMFS_F (consisting of: 85537MAYAMFS_2011_0F
14:44:05 (adskflex) 85400MAYAMFS_2010_0F)
14:44:05 (adskflex) 85530MAYAMMR_F (consisting of: 85537MAYAMMR_2011_0F
14:44:05 (adskflex) 85400MAYAMMR_2010_0F)
14:44:05 (adskflex) 85531MAYAMMR1_F (consisting of: 85537MAYAMMR1_2011_0F
14:44:05 (adskflex) 85400MAYAMMR1_2010_0F)
14:44:05 (adskflex) 85532MAYAMMR2_F (consisting of: 85537MAYAMMR2_2011_0F
14:44:05 (adskflex) 85400MAYAMMR2_2010_0F)
14:44:05 (adskflex) 85532MAYAMMR3_F (consisting of: 85537MAYAMMR3_2011_0F
14:44:05 (adskflex) 85400MAYAMMR3_2010_0F)
14:44:05 (adskflex) 85532MAYAMMR4_F (consisting of: 85537MAYAMMR4_2011_0F
14:44:05 (adskflex) 85400MAYAMMR4_2010_0F)
14:44:05 (adskflex) 85532MAYAMMR5_F (consisting of: 85537MAYAMMR5_2011_0F
14:44:05 (adskflex) 85400MAYAMMR5_2010_0F)
14:44:05 (adskflex) 79000SFTIMASIB1_F (consisting of: 85563SFTIMSIB1_2011_0F
14:44:05 (adskflex) 84100SFTIMASIB1_2010_0F 78800SFTIMASIB1_7_5F)
14:44:05 (adskflex) 79100SFTIMASIB2_F (consisting of: 85563SFTIMSIB2_2011_0F
14:44:05 (adskflex) 84100SFTIMASIB2_2010_0F 78800SFTIMASIB2_7_5F)
14:44:05 (adskflex) 79200SFTIMASIB3_F (consisting of: 85563SFTIMSIB3_2011_0F
14:44:05 (adskflex) 84100SFTIMASIB3_2010_0F 78800SFTIMASIB3_7_5F)
14:44:05 (adskflex) 79300SFTIMASIB4_F (consisting of: 85563SFTIMSIB4_2011_0F
14:44:05 (adskflex) 84100SFTIMASIB4_2010_0F 78800SFTIMASIB4_7_5F)
14:44:05 (adskflex) 79400SFTIMASIB5_F (consisting of: 85563SFTIMSIB5_2011_0F
14:44:05 (adskflex) 84100SFTIMASIB5_2010_0F 78800SFTIMASIB5_7_5F) PLIST
14:44:05 (adskflex) EXTERNAL FILTERS are OFF
14:44:05 (lmgrd) adskflex using TCP-port 2080
14:44:26 (adskflex) TCP_NODELAY NOT enabled
I've checked the firewall logs and can see the incoming connections from the clients, I've opened 2080 and 27000-27009 on the firewall. The system is 32 bit (it's fairly old hardware) running Ubuntu 10.04 so I shouldn't need the IPv6 update, should I?
When the clients say they can't find the license server I point them to the IP address of the server (it's all part of the same lan setup) but they eventually just time out again - any thoughts as to what might be happening?
11 REPLIES 11
Message 2 of 12
TravisNave
in reply to: ChrisJanes1578
Use the ADSKFLEX_LICENSE_FILE system environment variable and potentially the FLEXLM_TIMEOUT one too.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
Also double check connectivity with PING and make sure that you get an IPv4 response.  You can also check port numbers with Internet Explorer (not 3rd party) by placing your servername and port numbers in the address bar:
http://games-server:2080
http://games-server:27000
You should receive a jargon response similar to this:
Wê-60Wê-60Wê-60Wê-60Wê-60Wê-60Wê-60
If you get a 'page cannot be displayed' error, then your ports are blocked.
If all else fails, try deleting your CascadeInfo.cas file and try relaunching.
For more detailed information about the CascadeInfo.cas file, please refer to the Autodesk Support Knowledge Base article found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 12
ChrisJanes1578
in reply to: TravisNave
I've set the ADSKFLEX_LICENSE_FILE variable, the timeout was already set up.
I get an IPv4 IP back from ping (and IPv6 is completely disabled on the server) and both IE checks returned the jargon responses and I deleted the cascadeinfo file earlier today.
Still no licenses being returned.
Message 4 of 12
TravisNave
Are you getting any kind of Flexnet error number from your clients?  What is your TIMEOUT set to?  Start at one-million.
Autodesk Forums:
Message 5 of 12
ChrisJanes1578
The timeout is set to a million and the clients eventually error out with "A valid license could not be obtained by the network license manager." and error code 0.0.0.
It takes 5 or so retries of telling it the host name for the license server before it finally gives up the ghost and provides the error message.
Message 6 of 12
TravisNave
0.0.0 usually indicates either a problem with:
1.  The CascadeInfo.cas file
2.  The licensed product doesn't match the server
3.  The date/time on the server doesn't match the date/time on the client.
Since you mentioned that your server is ancient, make sure that the date, time, time-zone, and proper daylight saving time setting is set correctly on the server and matches the client connecting to it.
Autodesk Forums:
Message 7 of 12
ChrisJanes1578
The date and time match fine, I've had that issue pop up before so that was the first thing I checked.
I had a brief eureka moment at 2 when I realised that I may have gotten a license file for the 2011 suite rather than the 2012 so went ahead and made sure that was right via register.autodesk.com, it's definitely listing 2012 licenses as being issued now but no luck with actually getting it to provide one for use.
Message 8 of 12
TravisNave
Since the service changed to 2012, you might try deleting the CascadeInfo.cas file again and seeing if it connects.  Are there any debug errors being listed from the server for any kind of denial?
Autodesk Forums:
Message 9 of 12
ChrisJanes1578
It's not generated a new CascadeInfo.cas file since I deleted the original and the log output from the server is completely empty beyond the following:
10:55:12 (lmgrd) adskflex using TCP-port 2080
10:55:44 (adskflex) TCP_NODELAY NOT enabled
No connections or attempts to connect show up.
Message 10 of 12
So one machine was able to retrieve a license successfully, so I over-wrote the cascadeinfo file of another machine with the new one and it seems to be working fine now. Not at all sure what's happened to fix it, or even what broke, but it does for now seem to be ok. (touching wood)
Message 11 of 12
TravisNave
Thanks for the update.  Copying the CascadeInfo.cas file from another computer does work.  But it should only be done if the other computer has the same set of Autodesk applications installed.  Good job!
Autodesk Forums:
Message 12 of 12
Can someone provide a tutorial (or point me to one) for setting up NLM on Ubuntu?  I am completely new to Ubuntu, so it may need to begin at a fairly rudimentary level.
I am running a desktop version (12.04.3).  I assumed I would not need a server version, given NLM runs on non-server versions of Windows.  Correct me if I have already gone astray there.
Thanks for any help you can give.
Administrator Productivity
