Issue: When installing your Autodesk product, the installation fails immediately and the screen indicates that Installation complete. Some products failed to install.
The link to the installation log file in your %TEMP% location shows that the failure is due to a prerequisite installer similar to this entry below:
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Subseqent attempts to install the product yield similar failures.
Solution #1: In some rare instances, the prerequisite cannot installed until the workstation is rebooted, or cannot be installed by the Autodesk installer and must be installed manually from the media or by downloading the prerequisite directly from Microsoft's website. For more information about this solution, please visit this Autodesk KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15924324&linkID=9240857
Solution #2: In most instances, the installation fails because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer. Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
The most direct method to resolve this issue is to remove the installed prerequisite from Windows from within the Control Panel. You can launch the Control Panel directly from the Start Menu or from the Run box by typing CONTROL and clicking OK.
To remove a program in Control Panel choose:
Windows XP: Add/Remove Programs
Windows 7: Programs and Features
Locate the program name of the prerequisite that is failing in your log file from within this list and click Remove or Uninstall. This will remove the program from your computer.
Once the program has been removed, run your Autodesk installer again. If you run into additional failures on prerequisites, repeat the process. You should now be able to fully install and run your product.
For more information about this error, please see the Up and Ready blog link here:
Note: When installing Autodesk products, it is recommended that you have local Administrative rights, User Access Control (UAC) is off, and your real-time anti-virus program is temporarily disabled. In some instances it may be helpful to login as another user with local admin rights and/or copy the contents of the media to you hard drive and install locally.
Solved by dzanta. Go to Solution.
Solved by jessica.t. Go to Solution.
Solved by asburyj. Go to Solution.
Solved by TravisNave. Go to Solution.
@Anonymous, Please post a new thread with your installation log attached.
try doing what I was recommended to do.
-open your add or remove programs list from control panel. (If you don't know how to do this, perhaps this is a user issue, and you should find someone who knows how to use a PC to install the software)....
-Find Autodesk BIM 360 program (or whatever program resembles the BIM 360 name)
-Uninstall this program.
-restart your computer and attempt to reinstall the software you are attempting to install (for me, it was Civil3D)
if this does not work, then try all that other stuff they recommend...
I am finding it difficult to track just what the solutions options are in this forum as they seem to be going in multiple directions.
As well, they all seem to be at odds with what are static solutions posted across Autodesk help pages so, I am going to start from scratch.
I have multiple Autodesk products and recently have downloaded Revit 2015. I got past the download isues and have the .exe setup file on the computer.
I am getting the Error 1603 in the install log (antivirus is disabled)
I am running Windows 7 64 bit with all updates in place current as of today May 19th.
I downloaded the 64 bit program.
On install I get the 1603 error specifically referring to x86 2005 C++ (which is weird)
Autodesk's solution for this here and on static posts is to uninstall ALL other versions of C++ as they are all newer versions. Absurd since all there because they were installed in support of other programs...namely, Autodesk products.....
What you are stating is that in order to use this product, you must uninstall all other versions of C++, then install Revit (in my case)...then uninstall all my other Autodesk products, then make a clean reinstall of all of them (in the correct sequential order of C++ releases) or figure out what other programs outside of Autodesk products rely on those uninstalled C++ versions.....
And this is a "solution"?
I find this an unacceptable, unproffessional and simply a lame "solution" Agreed with those who say a $6000 + piece of software should NOT require such extreme and highly inconvenient steps. (If the forum moderators find this to be in agreement with their analysis and need a lending hand please, ask. I have excellent and well practice ability at writing letters that point out to decision makers what absolute morons they are for this "solution" and especialluy to have allowed it to go on for 3-4 years.
If I am reading things correctly, there may be other solutions via uninstalling some Autodesk components? 360? BIM?
Please advise
1603 is a generic error message so we have to see specificly which component is failing to know what solution to suggest. My suggestion would be start a new thread and post a copy of your setup log that you are linked to on the installation failure screen. With that we should be able to figure out which specific component is causing the 1603
I specifically stated in the original post that the error code in the log was due to Microsoft Visual C++ 2005 (x86).
If this is so generic, why put up a static web page with a "solution" that states this is the result of a common issue?
Could you upload a copy of your setup log? In the mean time, what happens if you try to install the pre-requisite from the link below?
http://www.microsoft.com/en-us/download/details.aspx?id=5638
This is the message I'm getting when AutoCAD is failing to install. Can someone please help?!
2015/6/2:16:34:28 Heather OWNER-HP === Setup started on OWNER-HP by Heather ===
2015/6/2:16:34:28 Heather OWNER-HP Path_Length: 155
2015/6/2:16:34:28 Heather OWNER-HP Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2015/6/2:16:34:28 Heather OWNER-HP Launch
2015/6/2:16:34:28 Heather OWNER-HP CommandLine /PK 001F1 /SN 900-60076998 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup....
2015/6/2:16:34:28 Heather OWNER-HP Current Directory C:\Users\Heather\AppData\Local\Temp\_AI5C71.tmp
2015/6/2:16:35:48 Heather OWNER-HP === Setup ended ===
2015/6/2:16:34:33 Heather OWNER-HP === Setup started on OWNER-HP by Heather ===
2015/6/2:16:34:33 Heather OWNER-HP Path_Length: 155
2015/6/2:16:34:33 Heather OWNER-HP Current Directory C:\Users\Heather\AppData\Local\Temp\_AI5C71.tmp
2015/6/2:16:34:33 Heather OWNER-HP Launch
2015/6/2:16:35:47 Heather OWNER-HP Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2015/6/2:16:35:47 Heather OWNER-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Heather\AppData\Local\Temp\_AI5C71.tmp\Setup\AcSetup.dll
2015/6/2:16:35:47 Heather OWNER-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/6/2:16:35:48 Heather OWNER-HP PageOpen LaunchDialog
2015/6/2:16:35:59 Heather OWNER-HP PageOpen LicenseDialog
2015/6/2:16:35:59 Heather OWNER-HP PageOpen ProductSelectionDialog2
2015/6/2:16:36:14 Heather OWNER-HP PageOpen LicenseDialog
2015/6/2:16:36:14 Heather OWNER-HP PageOpen LaunchDialog
2015/6/2:16:36:22 Heather OWNER-HP PageOpen LicenseDialog
2015/6/2:16:36:22 Heather OWNER-HP PageOpen ProductInfoDialog
2015/6/2:16:36:22 Heather OWNER-HP PageOpen ProductSelectionDialog2
2015/6/2:16:36:27 Heather OWNER-HP PageOpen FullProgressDialog
2015/6/2:16:36:28 Heather OWNER-HP Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:36:30 Heather OWNER-HP Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:36:30 Heather OWNER-HP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/6/2:16:36:39 Heather OWNER-HP Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2015/6/2:16:36:40 Heather OWNER-HP Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:36:42 Heather OWNER-HP Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:36:42 Heather OWNER-HP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/6/2:16:36:51 Heather OWNER-HP Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/6/2:16:36:51 Heather OWNER-HP Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:36:53 Heather OWNER-HP Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:36:53 Heather OWNER-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Heather\AppData\Local\Temp\vcredist_x86_2010.log
2015/6/2:16:37:05 Heather OWNER-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2015/6/2:16:37:05 Heather OWNER-HP Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:37:07 Heather OWNER-HP Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:16:37:07 Heather OWNER-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Heather\AppData\Local\Temp\vcredist_x64_2010.log
2015/6/2:16:37:21 Heather OWNER-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2015/6/2:16:37:22 Heather OWNER-HP Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2015/6/2:16:37:22 Heather OWNER-HP Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/6/2:16:38:41 Heather OWNER-HP Install DirectX Runtime Succeeded
2015/6/2:16:38:41 Heather OWNER-HP Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:16:38:43 Heather OWNER-HP Install FARO LS 5.1.0.30630 (64bit) Succeeded
2015/6/2:16:38:43 Heather OWNER-HP Download Skipped CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2015/6/2:16:38:44 Heather OWNER-HP Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:16:39:33 Heather OWNER-HP Install Autodesk Material Library 2014 Succeeded
2015/6/2:16:39:33 Heather OWNER-HP Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar....
2015/6/2:16:39:33 Heather OWNER-HP Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:16:40:00 Heather OWNER-HP Install Autodesk Material Library 2014 - Base Image Library Succeeded
2015/6/2:16:40:00 Heather OWNER-HP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:16:40:16 Heather OWNER-HP Install Autodesk Content Service Succeeded
2015/6/2:16:40:16 Heather OWNER-HP Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:16:40:26 Heather OWNER-HP Install Autodesk Content Service Language Pack Succeeded
2015/6/2:16:40:26 Heather OWNER-HP Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.t...
2015/6/2:16:40:26 Heather OWNER-HP Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Heather\AppData\Local\Temp\_AI5C71.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:16:48:36 Heather OWNER-HP Install Autodesk® AutoCAD® 2014 Succeeded
2015/6/2:16:48:37 Heather OWNER-HP Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64_e...
2015/6/2:16:50:19 Heather OWNER-HP Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64_e...
2015/6/2:16:50:19 Heather OWNER-HP Install AutoCAD® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2015/6/2:16:52:08 Heather OWNER-HP Rollback Autodesk® AutoCAD® 2014 Succeeded
2015/6/2:16:52:13 Heather OWNER-HP Rollback Autodesk Content Service Language Pack Succeeded
2015/6/2:16:52:22 Heather OWNER-HP Rollback Autodesk Content Service Succeeded
2015/6/2:16:52:50 Heather OWNER-HP Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2015/6/2:16:53:36 Heather OWNER-HP Rollback Autodesk Material Library 2014 Succeeded
2015/6/2:16:53:40 Heather OWNER-HP Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2015/6/2:16:53:40 Heather OWNER-HP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/6/2:16:53:40 Heather OWNER-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2015/6/2:16:53:41 Heather OWNER-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2015/6/2:16:53:42 Heather OWNER-HP PageOpen InstallCompleteDialog
2015/6/2:17:11:00 Heather OWNER-HP === Setup ended ===
2015/6/2:17:11:42 Heather OWNER-HP === Setup started on OWNER-HP by Heather ===
2015/6/2:17:11:42 Heather OWNER-HP Path_Length: 155
2015/6/2:17:11:42 Heather OWNER-HP Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2015/6/2:17:11:42 Heather OWNER-HP Launch
2015/6/2:17:11:42 Heather OWNER-HP CommandLine /PK 001F1 /SN 900-60076998 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup....
2015/6/2:17:11:42 Heather OWNER-HP Current Directory C:\Users\Heather\AppData\Local\Temp\_AI70BD.tmp
2015/6/2:17:11:50 Heather OWNER-HP === Setup ended ===
2015/6/2:17:11:45 Heather OWNER-HP === Setup started on OWNER-HP by Heather ===
2015/6/2:17:11:45 Heather OWNER-HP Path_Length: 155
2015/6/2:17:11:45 Heather OWNER-HP Current Directory C:\Users\Heather\AppData\Local\Temp\_AI70BD.tmp
2015/6/2:17:11:45 Heather OWNER-HP Launch
2015/6/2:17:11:46 Heather OWNER-HP Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2015/6/2:17:11:46 Heather OWNER-HP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Heather\AppData\Local\Temp\_AI70BD.tmp\Setup\AcSetup.dll
2015/6/2:17:11:46 Heather OWNER-HP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/6/2:17:11:47 Heather OWNER-HP PageOpen LaunchDialog
2015/6/2:17:11:56 Heather OWNER-HP PageOpen LicenseDialog
2015/6/2:17:11:56 Heather OWNER-HP PageOpen ProductInfoDialog
2015/6/2:17:11:56 Heather OWNER-HP PageOpen ProductSelectionDialog2
2015/6/2:17:12:01 Heather OWNER-HP PageOpen FullProgressDialog
2015/6/2:17:12:01 Heather OWNER-HP Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:17:12:01 Heather OWNER-HP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/6/2:17:12:07 Heather OWNER-HP Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2015/6/2:17:12:08 Heather OWNER-HP Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:17:12:08 Heather OWNER-HP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/6/2:17:12:13 Heather OWNER-HP Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/6/2:17:12:13 Heather OWNER-HP Download Skipped VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:17:12:13 Heather OWNER-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Heather\AppData\Local\Temp\vcredist_x86_2010.log
2015/6/2:17:12:21 Heather OWNER-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2015/6/2:17:12:21 Heather OWNER-HP Download Skipped VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST20...
2015/6/2:17:12:21 Heather OWNER-HP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Heather\AppData\Local\Temp\vcredist_x64_2010.log
2015/6/2:17:12:31 Heather OWNER-HP Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2015/6/2:17:12:31 Heather OWNER-HP Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2015/6/2:17:12:31 Heather OWNER-HP Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2015/6/2:17:13:34 Heather OWNER-HP Install DirectX Runtime Succeeded
2015/6/2:17:13:34 Heather OWNER-HP Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:17:14:06 Heather OWNER-HP Install FARO LS 5.1.0.30630 (64bit) Succeeded
2015/6/2:17:14:06 Heather OWNER-HP Download Skipped CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2015/6/2:17:14:06 Heather OWNER-HP Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:17:14:45 Heather OWNER-HP Install Autodesk Material Library 2014 Succeeded
2015/6/2:17:14:46 Heather OWNER-HP Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar....
2015/6/2:17:14:46 Heather OWNER-HP Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:17:15:13 Heather OWNER-HP Install Autodesk Material Library 2014 - Base Image Library Succeeded
2015/6/2:17:15:13 Heather OWNER-HP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:17:15:28 Heather OWNER-HP Install Autodesk Content Service Succeeded
2015/6/2:17:15:28 Heather OWNER-HP Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:17:15:35 Heather OWNER-HP Install Autodesk Content Service Language Pack Succeeded
2015/6/2:17:15:35 Heather OWNER-HP Download Skipped ACAD http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.t...
2015/6/2:17:15:36 Heather OWNER-HP Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Heather\AppData\Local\Temp\_AI70BD.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/6/2:17:24:34 Heather OWNER-HP Install Autodesk® AutoCAD® 2014 Succeeded
2015/6/2:17:24:35 Heather OWNER-HP Download Play ACAD_en-us http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64_e...
2015/6/2:17:26:02 Heather OWNER-HP Download Aborted ACAD_en-us http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64_e...
2015/6/2:17:26:02 Heather OWNER-HP Install AutoCAD® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2015/6/2:17:27:59 Heather OWNER-HP Rollback Autodesk® AutoCAD® 2014 Succeeded
2015/6/2:17:28:04 Heather OWNER-HP Rollback Autodesk Content Service Language Pack Succeeded
2015/6/2:17:28:14 Heather OWNER-HP Rollback Autodesk Content Service Succeeded
2015/6/2:17:28:43 Heather OWNER-HP Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2015/6/2:17:29:37 Heather OWNER-HP Rollback Autodesk Material Library 2014 Succeeded
2015/6/2:17:29:41 Heather OWNER-HP Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2015/6/2:17:29:41 Heather OWNER-HP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/6/2:17:29:42 Heather OWNER-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2015/6/2:17:29:42 Heather OWNER-HP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Im getting errors while trying to install, Please help
2015/6/12:11:09:42 Rao RAONGA === Setup started on RAONGA by Rao === 2015/6/12:11:09:42 Rao RAONGA Path_Length: 157 2015/6/12:11:09:42 Rao RAONGA Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us 2015/6/12:11:09:42 Rao RAONGA Launch 2015/6/12:11:09:42 Rao RAONGA CommandLine /PK 001G1 /SN 900-49161732 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_... 2015/6/12:11:09:42 Rao RAONGA Path_Length: 157 2015/6/12:11:09:42 Rao RAONGA Current Directory C:\Users\Rao\AppData\Local\Temp\_AI36AF.tmp 2015/6/12:12:51:56 Rao RAONGA === Setup ended === 2015/6/12:11:09:53 Rao RAONGA === Setup started on RAONGA by Rao === 2015/6/12:11:09:53 Rao RAONGA Path_Length: 157 2015/6/12:11:09:53 Rao RAONGA Current Directory C:\Users\Rao\AppData\Local\Temp\_AI36AF.tmp 2015/6/12:11:09:53 Rao RAONGA Launch 2015/6/12:11:31:20 Rao RAONGA Download Play SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE... 2015/6/12:11:31:23 Rao RAONGA Download Complete SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE... 2015/6/12:11:31:24 Rao RAONGA Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.... 2015/6/12:12:17:32 Rao RAONGA Download Error SETUP_CONFIG Network Error, cannot downloadCheck connections and try again. Would you like to retry now? http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.... 2015/6/12:12:44:21 Rao RAONGA Download Error SETUP_CONFIG Network Error, cannot downloadCheck connections and try again. Would you like to retry now? http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.... 2015/6/12:12:51:54 Rao RAONGA Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.... 2015/6/12:12:51:54 Rao RAONGA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rao\AppData\Local\Temp\_AI36AF.tmp\Setup\AcSetup.dll 2015/6/12:12:51:54 Rao RAONGA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2015/6/12:12:51:56 Rao RAONGA PageOpen LaunchDialog 2015/6/12:13:49:12 Rao RAONGA PageOpen LicenseDialog 2015/6/12:13:49:12 Rao RAONGA PageOpen ProductInfoDialog 2015/6/12:13:49:12 Rao RAONGA PageOpen ProductSelectionDialog2 2015/6/12:13:49:30 Rao RAONGA PageOpen FullProgressDialog 2015/6/12:13:49:37 Rao RAONGA Download Play STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE... 2015/6/12:13:49:39 Rao RAONGA Download Complete STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE... 2015/6/12:13:49:42 Rao RAONGA Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:13:52:37 Rao RAONGA Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:13:52:37 Rao RAONGA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2015/6/12:13:52:49 Rao RAONGA Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2015/6/12:13:52:53 Rao RAONGA Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:13:55:12 Rao RAONGA Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:13:55:12 Rao RAONGA Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2015/6/12:13:55:23 Rao RAONGA Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2015/6/12:13:55:25 Rao RAONGA Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:13:57:42 Rao RAONGA Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:13:57:42 Rao RAONGA Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Rao\AppData\Local\Temp\vcredist_x86_2010.log 2015/6/12:13:57:55 Rao RAONGA Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2015/6/12:13:57:59 Rao RAONGA Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:14:01:41 Rao RAONGA Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:14:01:41 Rao RAONGA Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Rao\AppData\Local\Temp\vcredist_x64_2010.log 2015/6/12:14:01:54 Rao RAONGA Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2015/6/12:14:01:57 Rao RAONGA Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:14:05:08 Rao RAONGA Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:14:05:08 Rao RAONGA Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Rao\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2015/6/12:14:06:15 Rao RAONGA Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2015/6/12:14:06:18 Rao RAONGA Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:14:09:58 Rao RAONGA Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/12:14:09:58 Rao RAONGA Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Rao\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2015/6/12:14:10:04 Rao RAONGA Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2015/6/12:14:10:07 Rao RAONGA Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta... 2015/6/12:14:22:54 Rao RAONGA Download Error DIRECTX Connection has expired.Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta... 2015/6/12:14:22:54 Rao RAONGA Download Aborted DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta... 2015/6/12:14:22:54 Rao RAONGA Install DirectX Runtime Failed Download Failed, Installation aborted, Result=1603 2015/6/12:14:22:55 Rao RAONGA Download Error CM Network Error, cannot downloadCheck connections and try again. Would you like to retry now? http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm... 2015/6/12:14:22:55 Rao RAONGA Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm... 2015/6/12:14:23:26 Rao RAONGA Download User Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm... 2015/6/12:14:46:39 Rao RAONGA Download Complete CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm... 2015/6/12:14:46:40 Rao RAONGA Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/6/12:14:47:31 Rao RAONGA Install Autodesk Material Library 2015 Succeeded 2015/6/12:14:47:35 Rao RAONGA Download Play CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.... 2015/6/12:14:50:28 Rao RAONGA Download Error CMILB Connection has expired.Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.... 2015/6/12:14:50:28 Rao RAONGA Download Aborted CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.... 2015/6/12:14:50:28 Rao RAONGA Install Autodesk Material Library 2015 - Base Image Library Failed Download Failed, Installation aborted, Result=1603 2015/6/12:14:51:36 Rao RAONGA Rollback Autodesk Material Library 2015 Succeeded 2015/6/12:14:51:36 Rao RAONGA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2015/6/12:14:51:37 Rao RAONGA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2015/6/12:14:51:37 Rao RAONGA Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2015/6/12:14:51:37 Rao RAONGA Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2015/6/12:14:51:48 Rao RAONGA PageOpen InstallCompleteDialog 2015/6/12:15:01:58 Rao RAONGA === Setup ended === 2015/6/16:22:24:43 Rao RAONGA === Setup started on RAONGA by Rao === 2015/6/16:22:24:43 Rao RAONGA Path_Length: 157 2015/6/16:22:24:43 Rao RAONGA Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us 2015/6/16:22:24:43 Rao RAONGA Launch 2015/6/16:22:24:43 Rao RAONGA CommandLine /PK 001G1 /SN 900-49161732 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_... 2015/6/16:22:24:43 Rao RAONGA Path_Length: 157 2015/6/16:22:24:43 Rao RAONGA Current Directory C:\Users\Rao\AppData\Local\Temp\_AIB205.tmp 2015/6/16:22:24:56 Rao RAONGA === Setup ended === 2015/6/16:22:24:49 Rao RAONGA === Setup started on RAONGA by Rao === 2015/6/16:22:24:49 Rao RAONGA Path_Length: 157 2015/6/16:22:24:49 Rao RAONGA Current Directory C:\Users\Rao\AppData\Local\Temp\_AIB205.tmp 2015/6/16:22:24:49 Rao RAONGA Launch 2015/6/16:22:24:51 Rao RAONGA Download Skipped SETUPMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKE... 2015/6/16:22:24:51 Rao RAONGA Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.... 2015/6/16:22:24:54 Rao RAONGA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Rao\AppData\Local\Temp\_AIB205.tmp\Setup\AcSetup.dll 2015/6/16:22:24:54 Rao RAONGA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2015/6/16:22:24:55 Rao RAONGA PageOpen LaunchDialog 2015/6/16:22:27:08 Rao RAONGA PageOpen LicenseDialog 2015/6/16:22:27:08 Rao RAONGA PageOpen ProductInfoDialog 2015/6/16:22:27:08 Rao RAONGA PageOpen ProductSelectionDialog2 2015/6/16:22:30:15 Rao RAONGA PageOpen FullProgressDialog 2015/6/16:22:30:25 Rao RAONGA Download Play STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE... 2015/6/16:22:30:28 Rao RAONGA Download Complete STARTMARKER http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKE... 2015/6/16:22:30:29 Rao RAONGA Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/16:22:30:29 Rao RAONGA Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Rao\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2015/6/16:22:30:33 Rao RAONGA Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2015/6/16:22:30:34 Rao RAONGA Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST20... 2015/6/16:22:30:34 Rao RAONGA Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Rao\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2015/6/16:22:30:35 Rao RAONGA Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2015/6/16:22:30:37 Rao RAONGA Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta... 2015/6/16:22:35:29 Rao RAONGA Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.ta... 2015/6/16:22:35:29 Rao RAONGA Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent 2015/6/16:22:35:41 Rao RAONGA Install DirectX Runtime Succeeded 2015/6/16:22:35:42 Rao RAONGA Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzm... 2015/6/16:22:35:42 Rao RAONGA Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/6/16:22:36:48 Rao RAONGA Install Autodesk Material Library 2015 Succeeded 2015/6/16:22:36:52 Rao RAONGA Download Play CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.... 2015/6/16:23:08:59 Rao RAONGA Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CMILB.tar.... 2015/6/16:23:08:59 Rao RAONGA Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/6/16:23:09:29 Rao RAONGA Install Autodesk Material Library 2015 - Base Image Library Succeeded 2015/6/16:23:09:31 Rao RAONGA Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2015\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/6/16:23:09:52 Rao RAONGA Install Autodesk Content Service Succeeded 2015/6/16:23:09:52 Rao RAONGA Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/6/16:23:09:59 Rao RAONGA Install Autodesk Content Service Language Pack Succeeded 2015/6/16:23:10:04 Rao RAONGA Download Play ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t... 2015/6/17:03:35:44 Rao RAONGA Download Error ACAD Connection has expired.Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t... 2015/6/17:03:35:47 Rao RAONGA Download Error ACAD Decompressing failed http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t... 2015/6/17:06:23:01 Rao RAONGA Download Aborted ACAD http://edutrial.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/ACAD_x64.t... 2015/6/17:06:23:01 Rao RAONGA Install Autodesk® AutoCAD® 2015 Failed Download Failed, Installation aborted, Result=1603 2015/6/17:06:23:09 Rao RAONGA Rollback Autodesk Content Service Language Pack Succeeded 2015/6/17:06:23:24 Rao RAONGA Rollback Autodesk Content Service Succeeded 2015/6/17:06:24:15 Rao RAONGA Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2015/6/17:06:25:26 Rao RAONGA Rollback Autodesk Material Library 2015 Succeeded 2015/6/17:06:25:26 Rao RAONGA Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2015/6/17:06:25:26 Rao RAONGA Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2015/6/17:06:25:26 Rao RAONGA Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Hello everyone!
Thank you for providing your installation log files. Please perform a clean uninstall to remove any residual installation and download files. Then please re-download your software following these steps:
· In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
· In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
· Turn off your personal firewall or VPN, if you use one.
· Disable UAC
· Close and reopen your preferred browser.
· Re-download from the Virtual Agent
If you continue to experience issues after that, please reply with further details. We look forward to hearing from you! Thanks!
Hi @Anonymous
Awesome! Glad to hear the solution works and you're able to fix the problem! Thanks for sharing with everyone in the community.
Hi there
i am trying to istall creative suite unltimate 2016 and i keep getting "installation complete, some products failed to install (some meaning all). I have followed the steps outlined in this thread, and I uninstalled microsoft visual c++ redistribute, all but 2012 because my computer will not allow me to uninstall it, each time I try it says the the program has stopped working. I tried the advaced setup by going into the .ini file and it makes no difference, I still cannot install. I am also wondering what impact unistalling the microsoft visual c++ redistribute programs will have on the rest of my programs. I have attempted everything listed on this thread and I am still getting nowhere, is there anything else I can do? Any help is greatly appreciated,
thanks
Thanks for yor help !!!
When trying to install Autocad 3D 2015 on a laptop with windows 10, the next message appear:
When i try to install this version of .net 4.5 in my laptop, a messeage appear telling me: "You already have installed .Net 4.5".
Certainly i have installed a version in my computer, but it seems to be that it is not compatible with Autocad due to the name of version at wich it is registred. The next image shows that it its registred as version 4.6.00079
For that reason i cannot install successfully Autocad 3D Plant, because the next screen is depicted:
Then when I open the installation log file, the next code in a notepad is showed:
2015/8/20:16:04:33 javier gan SARAHY18 === Setup started on SARAHY18 by javier gan === 2015/8/20:16:04:33 javier gan SARAHY18 Path_Length: 157 2015/8/20:16:04:33 javier gan SARAHY18 Current Directory C:\Users\FLACA_~1\AppData\Local\Temp\_AI658A.tmp 2015/8/20:16:04:33 javier gan SARAHY18 Launch 2015/8/20:16:04:33 javier gan SARAHY18 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\FLACA_~1\AppData\Local\Temp\_AI658A.tmp\Setup\AcSetup.dll 2015/8/20:16:04:33 javier gan SARAHY18 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2015/8/20:16:04:39 javier gan SARAHY18 PageOpen LaunchDialog 2015/8/20:16:04:41 javier gan SARAHY18 PageOpen LicenseDialog 2015/8/20:16:04:46 javier gan SARAHY18 PageOpen ProductInfoDialog 2015/8/20:16:05:08 javier gan SARAHY18 PageOpen ProductSelectionDialog2 2015/8/20:16:05:11 javier gan SARAHY18 PageOpen FullProgressDialog 2015/8/20:16:05:11 javier gan SARAHY18 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\FLACA_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2015/8/20:16:05:12 javier gan SARAHY18 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2015/8/20:16:05:12 javier gan SARAHY18 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\FLACA_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2015/8/20:16:05:13 javier gan SARAHY18 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2015/8/20:16:05:13 javier gan SARAHY18 Installing DirectX Runtime: "C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2015/8/20:16:05:38 javier gan SARAHY18 Install DirectX Runtime Succeeded 2015/8/20:16:05:39 javier gan SARAHY18 Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/20:16:06:17 javier gan SARAHY18 Install Autodesk Material Library 2015 Succeeded 2015/8/20:16:06:17 javier gan SARAHY18 Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/20:16:06:53 javier gan SARAHY18 Install Autodesk Material Library 2015 - Base Image Library Succeeded 2015/8/20:16:06:54 javier gan SARAHY18 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/20:16:07:19 javier gan SARAHY18 Install Autodesk Content Service Succeeded 2015/8/20:16:07:19 javier gan SARAHY18 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/20:16:07:26 javier gan SARAHY18 Install Autodesk Content Service Language Pack Succeeded 2015/8/20:16:07:26 javier gan SARAHY18 Installing Microsoft WSE 3.0 Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Plant 3D 2015" SETUP_PACKAGECODE={AF289D13-01D7-4764-B386-3282ACA363CC} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/20:16:07:28 javier gan SARAHY18 Install Microsoft WSE 3.0 Runtime Succeeded 2015/8/20:16:07:30 javier gan SARAHY18 Installing Autodesk® AutoCAD® Plant 3D 2015: TRANSFORMS="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\x64\en-us\PLNT3D\PLNT3D.mst;C:\Users\FLACA_~1\AppData\Local\Temp\_AI658A.tmp\x64\PLNT3D\PLNT3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Plant_3D_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/20:16:11:50 javier gan SARAHY18 Install Autodesk® AutoCAD® Plant 3D 2015 Failed Installation aborted, Result=1603 2015/8/20:16:11:52 javier gan SARAHY18 Rollback Microsoft WSE 3.0 Runtime Succeeded 2015/8/20:16:11:57 javier gan SARAHY18 Rollback Autodesk Content Service Language Pack Succeeded 2015/8/20:16:12:04 javier gan SARAHY18 Rollback Autodesk Content Service Succeeded 2015/8/20:16:12:34 javier gan SARAHY18 Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2015/8/20:16:13:24 javier gan SARAHY18 Rollback Autodesk Material Library 2015 Succeeded 2015/8/20:16:13:24 javier gan SARAHY18 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2015/8/20:16:13:24 javier gan SARAHY18 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2015/8/20:16:13:25 javier gan SARAHY18 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
I have already read the comments in the forums about how to fix this problem, where it is said to eliminate the preriquisites DOTNET
in the setup.ini file, save it and then run again the setup. I have done this procedure, but in contrast with the video posted about how
to do it, there is a code line that it is different. Next i attache the paragraph with the line with the word dotnet, and i do not know if
i have too to eliminate part of it o just lave it.
#============================= Deployment Info ============================= DEPLOYMENT_NAME= CLIENT_LOGGING=YES EXTRA_FILES=acad;*.exe:Setup:CER:eula:3rdParty\msi:nlsdl:3rdParty\NET\4\wcu\dotNetFramework:setupres:%lang%:content\Plant_Content #============================= Install Execute & UI Sequence =============================
Without erase the code line before mentioned, i do not solve the problem with the .Net 4.5
Another suggestion, says that it is needed to change the name of the file .NET 4.6.00073 to .NET 4.5 according to the
procedure shown in this link:
I have followed also this procedure, but there is a last step that i do not know how to do it; when finished all the procedure
shown in the link, how to change the name of the file .NET 4.00079 in my case to .NET 4.5
I really appreciate your brief response.
GOOD DAY !
Changing the version registry key in \HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client to 4.5 is currently the most reliable way to workaround the issue with .net version 4.6. Can you give us some detail on where you are getting stuck on that workaround?
Hi Jeffry,
I am trying to install Autodesk Revit 2015 on Windows 8.1, but it always failed.
I have saved the installation log files.
2015/8/26:14:50:06 Zhihui YZH === Setup started on YZH by Zhihui === 2015/8/26:14:50:06 Zhihui YZH Path_Length: 155 2015/8/26:14:50:06 Zhihui YZH Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US 2015/8/26:14:50:06 Zhihui YZH Launch 2015/8/26:14:50:06 Zhihui YZH CommandLine /PK 829G1 /SN 900-53619651 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US_Setup.exe" 2015/8/26:14:50:06 Zhihui YZH Path_Length: 155 2015/8/26:14:50:06 Zhihui YZH Current Directory C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp 2015/8/26:14:50:24 Zhihui YZH === Setup ended === 2015/8/26:14:50:08 Zhihui YZH === Setup started on YZH by Zhihui === 2015/8/26:14:50:08 Zhihui YZH Path_Length: 155 2015/8/26:14:50:08 Zhihui YZH Current Directory C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp 2015/8/26:14:50:08 Zhihui YZH Launch 2015/8/26:14:50:11 Zhihui YZH Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64.tar.lzma2 2015/8/26:14:50:24 Zhihui YZH Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64.tar.lzma2 2015/8/26:14:50:24 Zhihui YZH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp\Setup\RevitSetup.dll 2015/8/26:14:50:24 Zhihui YZH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2015/8/26:14:50:24 Zhihui YZH PageOpen LaunchDialog 2015/8/26:14:50:33 Zhihui YZH Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp\Setup\RevitSetup.dll 2015/8/26:14:50:33 Zhihui YZH Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink= 2015/8/26:14:51:55 Zhihui YZH PageOpen LicenseDialog 2015/8/26:14:51:55 Zhihui YZH PageOpen ProductInfoDialog 2015/8/26:14:51:55 Zhihui YZH PageOpen ProductSelectionDialog2 2015/8/26:14:52:20 Zhihui YZH PageOpen FullProgressDialog 2015/8/26:14:52:37 Zhihui YZH Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2008SP1X64.tar.lzma2 2015/8/26:14:52:40 Zhihui YZH Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2008SP1X64.tar.lzma2 2015/8/26:14:52:40 Zhihui YZH Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2015/8/26:14:53:01 Zhihui YZH Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2015/8/26:14:53:19 Zhihui YZH Download Play VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2005X86.tar.lzma2 2015/8/26:14:53:20 Zhihui YZH Download Complete VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2005X86.tar.lzma2 2015/8/26:14:53:20 Zhihui YZH Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Zhihui\AppData\Local\Temp\vcredist_x86_2005.log"" " 2015/8/26:14:53:41 Zhihui YZH Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2015/8/26:14:53:58 Zhihui YZH Download Play VCREDIST2005X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2005X64.tar.lzma2 2015/8/26:14:54:00 Zhihui YZH Download Complete VCREDIST2005X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2005X64.tar.lzma2 2015/8/26:14:54:00 Zhihui YZH Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Zhihui\AppData\Local\Temp\vcredist_x64_2005.log"" " 2015/8/26:14:54:19 Zhihui YZH Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2015/8/26:14:56:44 Zhihui YZH Download Error VCREDIST2012X86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X86.tar.lzma2 2015/8/26:14:56:45 Zhihui YZH Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X86.tar.lzma2 2015/8/26:14:57:18 Zhihui YZH Download User Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X86.tar.lzma2 2015/8/26:14:57:40 Zhihui YZH Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X86.tar.lzma2 2015/8/26:14:57:40 Zhihui YZH Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2015/8/26:14:58:02 Zhihui YZH Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2015/8/26:14:58:15 Zhihui YZH Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X64.tar.lzma2 2015/8/26:14:59:23 Zhihui YZH Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X64.tar.lzma2 2015/8/26:14:59:23 Zhihui YZH Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2015/8/26:14:59:30 Zhihui YZH Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2015/8/26:14:59:33 Zhihui YZH Download Play KB958314ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314ATLX86.tar.lzma2 2015/8/26:14:59:36 Zhihui YZH Download Complete KB958314ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314ATLX86.tar.lzma2 2015/8/26:14:59:36 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:14:59:46 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2015/8/26:14:59:58 Zhihui YZH Download Play KB958314MFCX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MFCX86.tar.lzma2 2015/8/26:15:00:08 Zhihui YZH Download Complete KB958314MFCX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MFCX86.tar.lzma2 2015/8/26:15:00:08 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:00:18 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2015/8/26:15:00:18 Zhihui YZH Download Play KB958314CRTX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CRTX86.tar.lzma2 2015/8/26:15:00:19 Zhihui YZH Download Complete KB958314CRTX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CRTX86.tar.lzma2 2015/8/26:15:00:19 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:00:26 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2015/8/26:15:00:26 Zhihui YZH Download Play KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OPENMPX86.tar.lzma2 2015/8/26:15:00:26 Zhihui YZH Download Complete KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OPENMPX86.tar.lzma2 2015/8/26:15:00:26 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:00:33 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2015/8/26:15:00:36 Zhihui YZH Download Play KB958314ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314ATLX64.tar.lzma2 2015/8/26:15:00:36 Zhihui YZH Download Complete KB958314ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314ATLX64.tar.lzma2 2015/8/26:15:00:36 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:00:42 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2015/8/26:15:00:54 Zhihui YZH Download Play KB958314MFCX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MFCX64.tar.lzma2 2015/8/26:15:01:32 Zhihui YZH Download Complete KB958314MFCX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MFCX64.tar.lzma2 2015/8/26:15:01:32 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:01:40 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2015/8/26:15:01:41 Zhihui YZH Download Play KB958314CRTX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CRTX64.tar.lzma2 2015/8/26:15:01:45 Zhihui YZH Download Complete KB958314CRTX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CRTX64.tar.lzma2 2015/8/26:15:01:45 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:01:53 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2015/8/26:15:01:53 Zhihui YZH Download Play KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OPENMPX64.tar.lzma2 2015/8/26:15:01:54 Zhihui YZH Download Complete KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OPENMPX64.tar.lzma2 2015/8/26:15:01:54 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:02:00 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2015/8/26:15:02:01 Zhihui YZH Download Play VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2005SP1ATLX64.tar.lzma2 2015/8/26:15:02:14 Zhihui YZH Download Complete VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2005SP1ATLX64.tar.lzma2 2015/8/26:15:02:14 Zhihui YZH Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Zhihui\AppData\Local\Temp\vcredist_x64_2005.log"" " 2015/8/26:15:02:38 Zhihui YZH Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded 2015/8/26:15:02:38 Zhihui YZH Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:02:52 Zhihui YZH Install FaroSDK Succeeded 2015/8/26:15:03:01 Zhihui YZH Download Play RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RCL2015_x64.tar.lzma2 2015/8/26:15:03:58 Zhihui YZH Download Complete RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RCL2015_x64.tar.lzma2 2015/8/26:15:03:58 Zhihui YZH Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:06:48 Zhihui YZH Install Autodesk® Revit® Content Libraries 2015 Succeeded 2015/8/26:15:06:49 Zhihui YZH Download Play RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64.tar.lzma2 2015/8/26:15:14:56 Zhihui YZH Download Complete RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64.tar.lzma2 2015/8/26:15:14:58 Zhihui YZH Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:16:19 Zhihui YZH Install Autodesk® Revit® 2015 Succeeded 2015/8/26:15:16:19 Zhihui YZH Download Play RVT2015_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64_en-US.tar.lzma2 2015/8/26:15:16:37 Zhihui YZH Download Complete RVT2015_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64_en-US.tar.lzma2 2015/8/26:15:16:37 Zhihui YZH Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\Zhihui\AppData\Local\Temp\_AI2091.tmp\_la65E9.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:16:48 Zhihui YZH Install Autodesk® Revit® 2015 Language Pack Succeeded 2015/8/26:15:16:48 Zhihui YZH Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:16:51 Zhihui YZH Install Autodesk Workflows 2015 Succeeded 2015/8/26:15:16:51 Zhihui YZH Download Play CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CM2015.tar.lzma2 2015/8/26:15:17:18 Zhihui YZH Download Complete CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CM2015.tar.lzma2 2015/8/26:15:17:18 Zhihui YZH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:17:39 Zhihui YZH Install Autodesk Material Library 2015 Succeeded 2015/8/26:15:17:39 Zhihui YZH Download Play CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILB2015.tar.lzma2 2015/8/26:15:18:12 Zhihui YZH Download Complete CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILB2015.tar.lzma2 2015/8/26:15:18:12 Zhihui YZH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:18:27 Zhihui YZH Install Autodesk Material Library 2015 - Base Image Library Succeeded 2015/8/26:15:18:27 Zhihui YZH Download Play CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015.tar.lzma2 2015/8/26:15:20:29 Zhihui YZH Download Complete CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015.tar.lzma2 2015/8/26:15:20:29 Zhihui YZH Installing Autodesk Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:20:48 Zhihui YZH Install Autodesk Material Library 2015 - Low Image Library Succeeded 2015/8/26:15:20:48 Zhihui YZH Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/26:15:20:52 Zhihui YZH Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2015/8/26:15:20:53 Zhihui YZH Download Play CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015.tar.lzma2 2015/8/26:15:27:02 Zhihui YZH Download Aborted CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015.tar.lzma2 2015/8/26:15:27:02 Zhihui YZH Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603 2015/8/26:15:27:03 Zhihui YZH Rollback Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2015/8/26:15:27:16 Zhihui YZH Rollback Autodesk Material Library 2015 - Low Image Library Succeeded 2015/8/26:15:27:30 Zhihui YZH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2015/8/26:15:27:53 Zhihui YZH Rollback Autodesk Material Library 2015 Succeeded 2015/8/26:15:27:54 Zhihui YZH Rollback Autodesk Workflows 2015 Succeeded 2015/8/26:15:28:00 Zhihui YZH Rollback Autodesk® Revit® 2015 Language Pack Succeeded 2015/8/26:15:29:48 Zhihui YZH Rollback Autodesk® Revit® 2015 Succeeded 2015/8/26:15:30:25 Zhihui YZH Rollback Autodesk® Revit® Content Libraries 2015 Succeeded 2015/8/26:15:30:27 Zhihui YZH Rollback FaroSDK Succeeded 2015/8/26:15:30:27 Zhihui YZH Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619 2015/8/26:15:30:31 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2015/8/26:15:30:34 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2015/8/26:15:30:37 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2015/8/26:15:30:39 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2015/8/26:15:30:43 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2015/8/26:15:30:46 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2015/8/26:15:30:50 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2015/8/26:15:30:51 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2015/8/26:15:30:51 Zhihui YZH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2015/8/26:15:30:51 Zhihui YZH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619 2015/8/26:15:30:51 Zhihui YZH Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2015/8/26:15:30:52 Zhihui YZH Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2015/8/26:15:30:52 Zhihui YZH PageOpen InstallCompleteDialog 2015/8/26:15:35:53 Zhihui YZH === Setup ended === 2015/8/27:21:31:35 Zhihui YZH === Setup started on YZH by Zhihui === 2015/8/27:21:31:35 Zhihui YZH Path_Length: 155 2015/8/27:21:31:35 Zhihui YZH Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US 2015/8/27:21:31:35 Zhihui YZH Launch 2015/8/27:21:31:35 Zhihui YZH CommandLine /PK 829G1 /SN 900-53619651 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US_Setup.exe" 2015/8/27:21:31:35 Zhihui YZH Path_Length: 155 2015/8/27:21:31:35 Zhihui YZH Current Directory C:\Users\Zhihui\AppData\Local\Temp\_AIEA9B.tmp 2015/8/27:21:31:49 Zhihui YZH === Setup ended === 2015/8/27:21:31:37 Zhihui YZH === Setup started on YZH by Zhihui === 2015/8/27:21:31:37 Zhihui YZH Path_Length: 155 2015/8/27:21:31:37 Zhihui YZH Current Directory C:\Users\Zhihui\AppData\Local\Temp\_AIEA9B.tmp 2015/8/27:21:31:37 Zhihui YZH Launch 2015/8/27:21:31:46 Zhihui YZH Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US_Setup.exe 2015/8/27:21:31:46 Zhihui YZH Connection has expired. Please reconnect to site.2015/8/27:21:31:50 Zhihui YZH === Setup ended === 2015/8/27:21:32:17 Zhihui YZH === Setup started on YZH by Zhihui === 2015/8/27:21:32:17 Zhihui YZH Path_Length: 155 2015/8/27:21:32:17 Zhihui YZH Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US 2015/8/27:21:32:17 Zhihui YZH Launch 2015/8/27:21:32:17 Zhihui YZH CommandLine /PK 829G1 /SN 900-53619651 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US_Setup.exe" 2015/8/27:21:32:17 Zhihui YZH Path_Length: 155 2015/8/27:21:32:17 Zhihui YZH Current Directory C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp 2015/8/27:21:32:22 Zhihui YZH === Setup ended === 2015/8/27:21:32:19 Zhihui YZH === Setup started on YZH by Zhihui === 2015/8/27:21:32:19 Zhihui YZH Path_Length: 155 2015/8/27:21:32:19 Zhihui YZH Current Directory C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp 2015/8/27:21:32:19 Zhihui YZH Launch 2015/8/27:21:32:22 Zhihui YZH Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64.tar.lzma2 2015/8/27:21:32:22 Zhihui YZH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp\Setup\RevitSetup.dll 2015/8/27:21:32:22 Zhihui YZH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2015/8/27:21:32:22 Zhihui YZH PageOpen LaunchDialog 2015/8/27:21:32:27 Zhihui YZH Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp\Setup\RevitSetup.dll 2015/8/27:21:32:27 Zhihui YZH Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink= 2015/8/27:21:33:03 Zhihui YZH PageOpen LicenseDialog 2015/8/27:21:33:03 Zhihui YZH PageOpen ProductInfoDialog 2015/8/27:21:33:03 Zhihui YZH PageOpen ProductSelectionDialog2 2015/8/27:21:33:17 Zhihui YZH PageOpen FullProgressDialog 2015/8/27:21:33:17 Zhihui YZH Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X86.tar.lzma2 2015/8/27:21:33:17 Zhihui YZH Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart 2015/8/27:21:33:22 Zhihui YZH Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded 2015/8/27:21:33:22 Zhihui YZH Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012X64.tar.lzma2 2015/8/27:21:33:22 Zhihui YZH Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart 2015/8/27:21:33:23 Zhihui YZH Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded 2015/8/27:21:33:23 Zhihui YZH Download Skipped KB958314ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314ATLX86.tar.lzma2 2015/8/27:21:33:23 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:33:27 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2015/8/27:21:33:28 Zhihui YZH Download Skipped KB958314MFCX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MFCX86.tar.lzma2 2015/8/27:21:33:28 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:33:35 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2015/8/27:21:33:35 Zhihui YZH Download Skipped KB958314CRTX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CRTX86.tar.lzma2 2015/8/27:21:33:35 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:33:42 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2015/8/27:21:33:42 Zhihui YZH Download Skipped KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OPENMPX86.tar.lzma2 2015/8/27:21:33:42 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:33:47 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2015/8/27:21:33:47 Zhihui YZH Download Skipped KB958314ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314ATLX64.tar.lzma2 2015/8/27:21:33:47 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:33:53 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2015/8/27:21:33:53 Zhihui YZH Download Skipped KB958314MFCX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MFCX64.tar.lzma2 2015/8/27:21:33:53 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:34:22 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2015/8/27:21:34:22 Zhihui YZH Download Skipped KB958314CRTX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CRTX64.tar.lzma2 2015/8/27:21:34:22 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:34:36 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2015/8/27:21:34:36 Zhihui YZH Download Skipped KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OPENMPX64.tar.lzma2 2015/8/27:21:34:36 Zhihui YZH Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:34:50 Zhihui YZH Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2015/8/27:21:34:50 Zhihui YZH Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:35:32 Zhihui YZH Install FaroSDK Succeeded 2015/8/27:21:35:32 Zhihui YZH Download Skipped RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RCL2015_x64.tar.lzma2 2015/8/27:21:35:32 Zhihui YZH Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:39:10 Zhihui YZH Install Autodesk® Revit® Content Libraries 2015 Succeeded 2015/8/27:21:39:10 Zhihui YZH Download Skipped RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64.tar.lzma2 2015/8/27:21:39:10 Zhihui YZH Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:41:22 Zhihui YZH Install Autodesk® Revit® 2015 Succeeded 2015/8/27:21:41:23 Zhihui YZH Download Skipped RVT2015_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64_en-US.tar.lzma2 2015/8/27:21:41:25 Zhihui YZH Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\Zhihui\AppData\Local\Temp\_AI8D14.tmp\_laE1EB.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:41:38 Zhihui YZH Install Autodesk® Revit® 2015 Language Pack Succeeded 2015/8/27:21:41:39 Zhihui YZH Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:41:47 Zhihui YZH Install Autodesk Workflows 2015 Succeeded 2015/8/27:21:41:47 Zhihui YZH Download Skipped CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CM2015.tar.lzma2 2015/8/27:21:41:47 Zhihui YZH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:42:10 Zhihui YZH Install Autodesk Material Library 2015 Succeeded 2015/8/27:21:42:11 Zhihui YZH Download Skipped CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILB2015.tar.lzma2 2015/8/27:21:42:11 Zhihui YZH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:42:30 Zhihui YZH Install Autodesk Material Library 2015 - Base Image Library Succeeded 2015/8/27:21:42:30 Zhihui YZH Download Skipped CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015.tar.lzma2 2015/8/27:21:42:30 Zhihui YZH Installing Autodesk Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:42:49 Zhihui YZH Install Autodesk Material Library 2015 - Low Image Library Succeeded 2015/8/27:21:42:49 Zhihui YZH Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2015/8/27:21:42:52 Zhihui YZH Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2015/8/27:21:42:52 Zhihui YZH Download Play CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015.tar.lzma2 2015/8/27:21:49:44 Zhihui YZH Download Aborted CMILM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015.tar.lzma2 2015/8/27:21:49:44 Zhihui YZH Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603 2015/8/27:21:49:45 Zhihui YZH Rollback Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded 2015/8/27:21:49:58 Zhihui YZH Rollback Autodesk Material Library 2015 - Low Image Library Succeeded 2015/8/27:21:50:10 Zhihui YZH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2015/8/27:21:50:31 Zhihui YZH Rollback Autodesk Material Library 2015 Succeeded 2015/8/27:21:50:33 Zhihui YZH Rollback Autodesk Workflows 2015 Succeeded 2015/8/27:21:50:39 Zhihui YZH Rollback Autodesk® Revit® 2015 Language Pack Succeeded 2015/8/27:21:52:25 Zhihui YZH Rollback Autodesk® Revit® 2015 Succeeded 2015/8/27:21:52:58 Zhihui YZH Rollback Autodesk® Revit® Content Libraries 2015 Succeeded 2015/8/27:21:53:02 Zhihui YZH Rollback FaroSDK Succeeded 2015/8/27:21:53:05 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded 2015/8/27:21:53:08 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded 2015/8/27:21:53:12 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded 2015/8/27:21:53:14 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded 2015/8/27:21:53:16 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded 2015/8/27:21:53:20 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded 2015/8/27:21:53:24 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded 2015/8/27:21:53:25 Zhihui YZH Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded 2015/8/27:21:53:25 Zhihui YZH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619 2015/8/27:21:53:25 Zhihui YZH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Since the discussion in the forums is too much, I am not so clear how should I do to fix the problem. I really appreciate if you can provide me with some help.
When I receive clients that have this error, here is what I give them to get the issue resolved and it works 99% of the time:
Steps to install Autodesk software Worst Case Scenario:
Stage 1:
1. Start with clean computer (Windows 7 OS ONLY! - NO ANTI-VIRUS, ANTI-MALWARE, MS OFFICE, .NET, C++, ETC.)
2. Install Autodesk software as normal
Stage 2
(If Stage 1 fails...)
1. Remove ALL Autodesk software CLEAN
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
2. Remove all files located at:
C:\Windows\Temp
C:\%User%\AppData\Local\Temp
3. Remove all .NET and all C++ Redistributable files (removing .net 4 extended then client profile)
4. Reboot system
5. Run .Net cleanup utility if necessary
6. Run CCleaner to clean up the registry
7. Install Autodesk software with NO Updates AND 1 software at a time
8. Verify installation of 1 product functionality
9. Proceed to install all other software 1 at a time
10. Verify installation of all products
11. Install updates to Autodesk software
12. Reboot system
13. Install Anti-virus/anti-spam/anti-malware software
14. Install Microsoft Updates as usual
15. Reboot system
Stage 3
(If Stage 2 fails...)
1. Gather installation log files
2. Write down all steps taken prior to getting to this point
3. Call Autodesk Technical Support
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
I tried to install Maya 2015 (also tried Maya2016) on my new laptop with Window's 10. I got below message. Can anyone help please?
Sam
