Installation & Licensing
Some Products Fail to Install, Result 1603
280 REPLIES 280
Message 1 of 281
TravisNave
807521 Views, 280 Replies
Issue:  When installing your Autodesk product, the installation fails immediately and the screen indicates that Installation complete. Some products failed to install
The link to the installation log file in your %TEMP% location shows that the failure is due to a prerequisite installer similar to this entry below:
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Subseqent attempts to install the product yield similar failures.
Solution #1:  In some rare instances, the prerequisite cannot installed until the workstation is rebooted, or cannot be installed by the Autodesk installer and must be installed manually from the media or by downloading the prerequisite directly from Microsoft's website.  For more information about this solution, please visit this Autodesk KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15924324&linkID=9240857
Solution #2:  In most instances, the installation fails because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer.  Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
The most direct method to resolve this issue is to remove the installed prerequisite from Windows from within the Control Panel.  You can launch the Control Panel directly from the Start Menu or from the Run box by typing CONTROL and clicking OK.
To remove a program in Control Panel choose:
Windows XP: Add/Remove Programs
Windows 7:  Programs and Features
Locate the program name of the prerequisite that is failing in your log file from within this list and click Remove or Uninstall.  This will remove the program from your computer.
Once the program has been removed, run your Autodesk installer again.  If you run into additional failures on prerequisites, repeat the process.  You should now be able to fully install and run your product.
For more information about this error, please see the Up and Ready blog link here:
http://upandready.typepad.com/up_and_ready/2011/09/autodesk-suites-product-design-suite-will-not-ins...
Note:  When installing Autodesk products, it is recommended that you have local Administrative rights, User Access Control (UAC) is off, and your real-time anti-virus program is temporarily disabled. In some instances it may be helpful to login as another user with local admin rights and/or copy the contents of the media to you hard drive and install locally.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Tags (2)
280 REPLIES 280
Message 121 of 281
dzanta
in reply to: lynn_zhang
1603 error is a common error.  you will need to do the following:
Steps to install Autodesk software Worst Case Scenario:
Stage 1:
1. Start with clean computer (Windows 7 OS ONLY! - NO ANTI-VIRUS, ANTI-MALWARE, MS OFFICE, .NET, C++, ETC.)
2. Install Autodesk BDSU 2013 normal
Stage 2
(If Stage 1 fails...)
1. Remove ALL Autodesk software CLEAN
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
2. Remove all files located at:
C:\Windows\Temp
C:\%User%\AppData\Local\Temp
3. Remove all .NET and all C++ Redistributable files (removing .net 4 extended then client profile)
4. Reboot system
5. Run .Net cleanup utility if necessary
6. Run CCleaner to clean up the registry
7. Install Autodesk software with NO Updates AND 1 software at a time
8. Verify installation of 1 product functionality
9. Proceed to install all other software 1 at a time
10. Verify installation of all products
11. Install updates to Autodesk software
12. Reboot system
13. Install Anti-virus/anti-spam/anti-malware software
14. Install Microsoft Updates as usual
15. Reboot system
Stage 3
(If Stage 2 fails...)
1. Gather installation log files
2. Write down all steps taken prior to getting to this point
3. Call Autodesk Technical Support
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 122 of 281
sam12050000
in reply to: dzanta
Hi Denza Ta,
I really appreciate your response, but this is not the solution in my case.
My professor can install Maya 2015 on window's 10 OS. Please help if you can.
Sam Yang
Message 123 of 281
maxxhome
in reply to: sam12050000
Alternative solution (in Windows 10) is to remove this folder (just renami it):
C:\ProgramData\Microsoft\Crypto\RSA\S-1-5-18\
More information on topic:
http://www.maxxpreston.pl/tech/overlapped-io-operation-is-in-progress/
Message 124 of 281
C:\Windows\Temp
Totally worked Thanks 🙂
Message 125 of 281
Sirkura
in reply to: subbz2k
i'm guessing the 1619 error for 3ds max is similar to this? (direct X fails to install) Why is this like this? it shouldn't be that hard to make a simple software check. (i can understand old software but come on, 2016 products?) my laptop has everything upgraded to the most current plug ins available, i'd REALLY prefer not to have to go thru a lengthy work around, or downgrade only to upgrade them again. that's just really poor design,
Message 126 of 281
TravisNave
in reply to: Sirkura
1619 is a rollback error and is never the reason for the failure. If you
are having an issue please start a new thread and post your log file.
Thanks!
Autodesk Forums:
Message 127 of 281
nieldgrace
in reply to: TravisNave
Hi, im not that tech smart so please can you not responde with difficult words and easy step by step if you could, i can not understand any of the prior infrmation submitted. im sorry.
i needed to download the maya education softwhere for class work. i had this on my old laptop and it worked fine and i dont think its down to any probems with this laptop. But when i downloded the softwhere like last time it abruptly said it had finished downloading and said some files didnt download and there were X's on all of them. Im trying to get Maya 2015 from the free for education page.
i have just got this laptop tday so i havent got anything bad downloaded to be coruptive.
im not sure what is going on. Please can somene help.
(i have a learning dficulty so sory for the spelling)
Message 128 of 281
TravisNave
in reply to: nieldgrace
Post your installation log file that's a blue link next to your red Xs.
Autodesk Forums:
Message 129 of 281
nieldgrace
2015/11/4:23:58:25 nield DESKTOP-UE56QT2 === Setup started on DESKTOP-UE56QT2 by nield ===
2015/11/4:23:58:25 nield DESKTOP-UE56QT2 Path_Length: 143
2015/11/4:23:58:25 nield DESKTOP-UE56QT2 Current Directory C:\Autodesk\Autodesk_Maya_2015_R1_wi_en-US
2015/11/4:23:58:25 nield DESKTOP-UE56QT2 Launch
2015/11/4:23:58:25 nield DESKTOP-UE56QT2 CommandLine /PK 657G1 /SN 900-58283985 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_R1_wi_en-US_Setup.exe?dummy=0...
2015/11/4:23:58:25 nield DESKTOP-UE56QT2 Current Directory C:\Users\nield\AppData\Local\Temp\_AI52.tmp
2015/11/5:00:00:25 nield DESKTOP-UE56QT2 === Setup ended ===
2015/11/4:23:58:28 nield DESKTOP-UE56QT2 === Setup started on DESKTOP-UE56QT2 by nield ===
2015/11/4:23:58:28 nield DESKTOP-UE56QT2 Path_Length: 143
2015/11/4:23:58:28 nield DESKTOP-UE56QT2 Current Directory C:\Users\nield\AppData\Local\Temp\_AI52.tmp
2015/11/4:23:58:28 nield DESKTOP-UE56QT2 Launch
2015/11/4:23:59:13 nield DESKTOP-UE56QT2 Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2015/11/5:00:00:24 nield DESKTOP-UE56QT2 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{18B8E8C8-C6C9-4E94-9125-3840D664A677}/SETUP_x64...
2015/11/5:00:00:26 nield DESKTOP-UE56QT2 PageOpen LaunchDialog
2015/11/5:00:02:29 nield DESKTOP-UE56QT2 PageOpen LicenseDialog
2015/11/5:00:02:29 nield DESKTOP-UE56QT2 PageOpen ProductSelectionDialog2
2015/11/5:00:02:42 nield DESKTOP-UE56QT2 PageOpen FullProgressDialog
2015/11/5:00:02:42 nield DESKTOP-UE56QT2 Installing Network License Manager:   INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2015" SETUP_PACKAGECODE={1A5DD79A-51E4-43EF-90D1-F6751239AF6E} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2015" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/11/5:00:02:45 nield DESKTOP-UE56QT2 Install Network License Manager Succeeded
2015/11/5:00:02:45 nield DESKTOP-UE56QT2 PageOpen InstallCompleteDialog
2015/11/5:00:02:56 nield DESKTOP-UE56QT2 === Setup ended ===
i have two of the blue links the on above is under AutoDesk Maya 2015
and the one posted below is Auto Desk connect 2015.
poth ths appeared on the same page.
sorry for the long post.
2015/11/5:00:03:48 nield DESKTOP-UE56QT2 === Setup started on DESKTOP-UE56QT2 b
Message 130 of 281
dzanta
Error 1603 is a common error.  From your installation log files it looks like you are trying to install Autodesk Network License Manager software during your Maya installation process.  Are you installing this as a standalone or a network based installation?  If it is standalone, you would not see the Network License Manager software being installed on a desktop operating system.  Also, error 1603 usually means there is a conflict between the C++ and .NET files on your computer and the same files on the installation software (installation software C++ and .NET files are older).
Do the following:
1.  Open Windows Explorer and type %Temp%...delete all files within this temp folder
2.  Go to C:\Windows\Temp and delete all the files within this temp folder
3.  Go to Control Panel, Add Remove Programs and remove all .NET and Microsoft Visual C++ Redistributable files
4.  Turn off Anti-virus/anti-malware software
5.  Download the Autodesk Installation files for your Autodesk software again (assuming your installation files are corrupt):
          go to www.upandready.typepad.com
          use the Ask Virtual Agent button on right to open new Download Links window
          find your Maya 2015 product and download all files
          extract the files by double-clicking on the first one after all files are downloaded...the installation files will decompress to C:\Autodesk subfolder
6.  Setup.exe should start automatically
7.  Ensure you specify standalone installation...NOT network installation
8.  Proceed as usual during installation (Make sure you have web access during installation)
Message 131 of 281
nieldgrace
in reply to: dzanta
Im sorry thoses words still didnt makke sence to me but thanks for your help 😄
I tried to follow the best i could but may have lost you on the way beacuse i felt asthough i was uninstalling anythin fro mmy laptop at one plint.
some said to uninsatll microsoft c++ or something for my computer wich i did.  and then to run the file throgh administrator (?) wich i think i did.
but then this message showed up:
any advice? 😄
sorry if i didnt fully follow your advice.
Message 132 of 281
dzanta
this error just means you do not have web access during the installation.  make sure your computer has web access prior to installing the software and during the installation process.
Message 133 of 281
nieldgrace
in reply to: dzanta
internet wasnt on? i think thats what you mean
it was on becuase i was doing other things on the internet so i dont see why it shouldnt be working?
is it because i have macfee could thta be blocking its download?
im worried about removing it though since the only reason i have a new laptop was that the last one was full of bugs and viruses.
but if it is the problem do you know of anyway to temperllay disbling it till i get the download?
am i close to completing the downlaod?
thanks again 😄
Message 134 of 281
dzanta
you should be able to temporarily disable your mcafee software
Message 135 of 281
nieldgrace
in reply to: dzanta
Thanks for your help i have managed to download it now!!!! 😄 , Mcfee wasnt alowing me to get the download so i temperaly disabled it an then it downloaded! ,thanks again 😄
Message 136 of 281
aerosj44
No matter how hard ones try you will always have a mishap. In this result, it is wise to go higher of even lower. We must learn the art of adjustment.
Message 137 of 281
DigoVargas
I'm trying to install Maya 2016 and Maya 2015 but always appears an error "Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619".
I removed and installed Microsoft Visual C++, disable McAfee and the error persists.
I don't know if the instalation log can help, so I'll post it here:
2015/11/21:14:25:20 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:14:25:20 Rodrigo RODRIGO Path_Length: 153
2015/11/21:14:25:20 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/21:14:25:20 Rodrigo RODRIGO Launch
2015/11/21:14:25:20 Rodrigo RODRIGO CommandLine /PK 657H1 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/21:14:25:20 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC7B1.tmp
2015/11/21:14:26:54 Rodrigo RODRIGO === Setup ended ===
2015/11/21:14:25:25 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:14:25:25 Rodrigo RODRIGO Path_Length: 153
2015/11/21:14:25:25 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC7B1.tmp
2015/11/21:14:25:25 Rodrigo RODRIGO Launch
2015/11/21:14:26:45 Rodrigo RODRIGO Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/21:14:26:46 Rodrigo RODRIGO Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/21:14:26:46 Rodrigo RODRIGO Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/21:14:26:52 Rodrigo RODRIGO Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/21:14:26:54 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/21:14:27:15 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/21:14:27:15 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/21:14:42:59 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/21:14:43:04 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/21:14:43:05 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/21:14:43:05 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/21:14:43:05 Rodrigo RODRIGO Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:08 Rodrigo RODRIGO Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:08 Rodrigo RODRIGO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2015/11/21:14:43:28 Rodrigo RODRIGO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2015/11/21:14:43:28 Rodrigo RODRIGO Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:30 Rodrigo RODRIGO Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:30 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/21:14:43:32 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/21:14:43:32 Rodrigo RODRIGO Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:34 Rodrigo RODRIGO Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:34 Rodrigo RODRIGO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/11/21:14:43:54 Rodrigo RODRIGO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/11/21:14:43:55 Rodrigo RODRIGO Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:57 Rodrigo RODRIGO Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:43:57 Rodrigo RODRIGO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2015/11/21:14:44:06 Rodrigo RODRIGO Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2015/11/21:14:44:06 Rodrigo RODRIGO Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:44:08 Rodrigo RODRIGO Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:44:08 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/21:14:44:11 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/21:14:44:11 Rodrigo RODRIGO Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/21:14:44:13 Rodrigo RODRIGO Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/21:14:44:13 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/21:14:44:18 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/21:14:44:18 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/21:14:47:09 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/21:14:47:09 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/21:14:47:09 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/21:14:47:10 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/21:14:47:10 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/21:14:47:10 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/21:14:47:10 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/21:14:47:11 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/21:14:47:28 Rodrigo RODRIGO === Setup ended ===
2015/11/21:14:52:36 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:14:52:36 Rodrigo RODRIGO Path_Length: 153
2015/11/21:14:52:36 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/21:14:52:36 Rodrigo RODRIGO Launch
2015/11/21:14:52:36 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/21:14:52:36 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC546.tmp
2015/11/21:14:52:38 Rodrigo RODRIGO === Setup ended ===
2015/11/21:14:52:37 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:14:52:37 Rodrigo RODRIGO Path_Length: 153
2015/11/21:14:52:37 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC546.tmp
2015/11/21:14:52:37 Rodrigo RODRIGO Launch
2015/11/21:14:52:38 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/21:14:52:38 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/21:14:52:38 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/21:14:52:53 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/21:14:52:53 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/21:14:52:53 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/21:14:52:56 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/21:14:52:58 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/21:14:52:58 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/21:14:52:58 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:52:58 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/21:14:52:59 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/21:14:52:59 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:14:52:59 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/21:14:53:00 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/21:14:53:00 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/21:14:53:00 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/21:14:53:03 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/21:14:53:05 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/21:14:56:07 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/21:14:56:07 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/21:14:56:07 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/21:14:56:08 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/21:14:56:08 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/21:14:56:09 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/21:15:02:13 Rodrigo RODRIGO === Setup ended ===
2015/11/21:15:00:27 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:15:00:27 Rodrigo RODRIGO Path_Length: 153
2015/11/21:15:00:27 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/21:15:00:27 Rodrigo RODRIGO Launch
2015/11/21:15:00:27 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/21:15:00:27 Rodrigo RODRIGO Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2015/11/21:15:06:34 Rodrigo RODRIGO === Setup ended ===
2015/11/21:15:28:56 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:15:28:56 Rodrigo RODRIGO Path_Length: 153
2015/11/21:15:28:56 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/21:15:28:56 Rodrigo RODRIGO Launch
2015/11/21:15:28:56 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/21:15:28:56 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI7A34.tmp
2015/11/21:15:28:59 Rodrigo RODRIGO === Setup ended ===
2015/11/21:15:28:57 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/21:15:28:57 Rodrigo RODRIGO Path_Length: 153
2015/11/21:15:28:57 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI7A34.tmp
2015/11/21:15:28:57 Rodrigo RODRIGO Launch
2015/11/21:15:28:58 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/21:15:28:58 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/21:15:28:59 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/21:15:29:08 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/21:15:29:08 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/21:15:29:08 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/21:15:29:30 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/21:15:29:32 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/21:15:29:33 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/21:15:29:33 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:15:29:33 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/21:15:29:36 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/21:15:29:36 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/21:15:29:36 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/21:15:29:37 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/21:15:29:37 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/21:15:29:37 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/21:15:29:41 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/21:15:29:41 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/21:15:32:35 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/21:15:32:35 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/21:15:32:35 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/21:15:32:35 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/21:15:32:36 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/21:15:32:36 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/21:15:56:53 Rodrigo RODRIGO === Setup ended ===
2015/11/22:15:20:30 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:15:20:30 Rodrigo RODRIGO Path_Length: 153
2015/11/22:15:20:30 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/22:15:20:30 Rodrigo RODRIGO Launch
2015/11/22:15:20:30 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/22:15:20:30 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AICB64.tmp
2015/11/22:15:20:31 Rodrigo RODRIGO === Setup ended ===
2015/11/22:15:20:31 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:15:20:31 Rodrigo RODRIGO Path_Length: 153
2015/11/22:15:20:31 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AICB64.tmp
2015/11/22:15:20:31 Rodrigo RODRIGO Launch
2015/11/22:15:20:31 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/22:15:20:31 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/22:15:20:31 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/22:15:21:57 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/22:15:21:57 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/22:15:21:57 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/22:15:22:04 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/22:15:22:04 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:15:22:05 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:15:22:05 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:15:22:05 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/22:15:22:28 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/22:15:22:28 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:15:22:28 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/22:15:23:13 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/22:15:23:13 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/22:15:23:13 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/22:15:23:44 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/22:15:23:44 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:15:26:36 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:15:26:36 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/22:15:26:38 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/22:15:26:39 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/22:15:26:39 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/22:15:26:39 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/22:15:30:37 Rodrigo RODRIGO === Setup ended ===
2015/11/22:15:48:05 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:15:48:05 Rodrigo RODRIGO Path_Length: 153
2015/11/22:15:48:05 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/22:15:48:05 Rodrigo RODRIGO Launch
2015/11/22:15:48:05 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/22:15:48:05 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC8B.tmp
2015/11/22:15:48:07 Rodrigo RODRIGO === Setup ended ===
2015/11/22:15:48:06 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:15:48:06 Rodrigo RODRIGO Path_Length: 153
2015/11/22:15:48:06 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIC8B.tmp
2015/11/22:15:48:06 Rodrigo RODRIGO Launch
2015/11/22:15:48:06 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/22:15:48:06 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/22:15:48:07 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/22:15:48:20 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/22:15:48:20 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/22:15:48:20 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/22:15:48:38 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/22:15:48:38 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:15:48:38 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:15:48:39 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:15:48:39 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/22:15:48:40 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/22:15:48:40 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:15:48:40 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/22:15:48:41 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/22:15:48:41 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/22:15:48:41 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/22:15:48:45 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/22:15:48:45 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:15:51:09 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:15:51:09 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/22:15:51:10 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/22:15:51:10 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/22:15:51:11 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/22:15:51:11 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/22:16:03:08 Rodrigo RODRIGO === Setup ended ===
2015/11/22:16:03:47 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:16:03:47 Rodrigo RODRIGO Path_Length: 153
2015/11/22:16:03:47 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/22:16:03:47 Rodrigo RODRIGO Launch
2015/11/22:16:03:47 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/22:16:03:47 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI6C4A.tmp
2015/11/22:16:03:48 Rodrigo RODRIGO === Setup ended ===
2015/11/22:16:03:48 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:16:03:48 Rodrigo RODRIGO Path_Length: 153
2015/11/22:16:03:48 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI6C4A.tmp
2015/11/22:16:03:48 Rodrigo RODRIGO Launch
2015/11/22:16:03:48 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/22:16:03:48 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/22:16:03:48 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/22:16:03:53 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/22:16:03:53 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/22:16:03:53 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/22:16:04:05 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/22:16:04:06 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:16:04:06 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:16:04:07 Rodrigo RODRIGO Download Play VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:09 Rodrigo RODRIGO Download Complete VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:09 Rodrigo RODRIGO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/11/22:16:04:27 Rodrigo RODRIGO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2015/11/22:16:04:27 Rodrigo RODRIGO Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:29 Rodrigo RODRIGO Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:29 Rodrigo RODRIGO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/11/22:16:04:44 Rodrigo RODRIGO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2015/11/22:16:04:44 Rodrigo RODRIGO Download Skipped VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:44 Rodrigo RODRIGO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2015/11/22:16:04:53 Rodrigo RODRIGO Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2015/11/22:16:04:53 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:53 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/22:16:04:56 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/22:16:04:56 Rodrigo RODRIGO Download Play VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:57 Rodrigo RODRIGO Download Complete VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:04:57 Rodrigo RODRIGO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Rodrigo\AppData\Local\Temp\vcredist_x64_2005.log"" "
2015/11/22:16:05:12 Rodrigo RODRIGO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2015/11/22:16:05:13 Rodrigo RODRIGO Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:05:13 Rodrigo RODRIGO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/11/22:16:05:28 Rodrigo RODRIGO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/11/22:16:05:28 Rodrigo RODRIGO Download Skipped VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:05:28 Rodrigo RODRIGO Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2015/11/22:16:05:35 Rodrigo RODRIGO Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2015/11/22:16:05:35 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:05:35 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/22:16:05:37 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/22:16:05:37 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/22:16:05:37 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/22:16:05:41 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/22:16:05:41 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:16:08:01 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:16:08:01 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/22:16:08:01 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/22:16:08:02 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/22:16:08:02 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/22:16:08:03 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/22:16:08:03 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/22:16:08:04 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/22:16:11:21 Rodrigo RODRIGO === Setup ended ===
2015/11/22:16:12:29 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:16:12:29 Rodrigo RODRIGO Path_Length: 153
2015/11/22:16:12:29 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/22:16:12:29 Rodrigo RODRIGO Launch
2015/11/22:16:12:29 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/22:16:12:29 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI659C.tmp
2015/11/22:16:12:31 Rodrigo RODRIGO === Setup ended ===
2015/11/22:16:12:30 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:16:12:30 Rodrigo RODRIGO Path_Length: 153
2015/11/22:16:12:30 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AI659C.tmp
2015/11/22:16:12:30 Rodrigo RODRIGO Launch
2015/11/22:16:12:30 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/22:16:12:30 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/22:16:12:31 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/22:16:12:36 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/22:16:12:36 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/22:16:12:36 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/22:16:13:19 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/22:16:13:20 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:16:13:21 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:16:13:21 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:13:21 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/22:16:13:21 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/22:16:13:21 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:13:21 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/22:16:13:22 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/22:16:13:22 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/22:16:13:22 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/22:16:13:25 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/22:16:13:25 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:16:17:40 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:16:17:40 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/22:16:17:42 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/22:16:17:42 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/22:16:17:42 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/22:16:17:43 Rodrigo RODRIGO PageOpen InstallCompleteDialog
2015/11/22:16:22:11 Rodrigo RODRIGO === Setup ended ===
2015/11/22:16:46:52 Rodrigo RODRIGO === Setup started on RODRIGO by Rodrigo ===
2015/11/22:16:46:52 Rodrigo RODRIGO Path_Length: 153
2015/11/22:16:46:52 Rodrigo RODRIGO Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2015/11/22:16:46:52 Rodrigo RODRIGO Launch
2015/11/22:16:46:52 Rodrigo RODRIGO CommandLine /PK 657H1 /SN 900-27380240 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2015/11/22:16:46:52 Rodrigo RODRIGO Current Directory C:\Users\Rodrigo\AppData\Local\Temp\_AIDD85.tmp
2015/11/22:16:46:55 Rodrigo RODRIGO === Setup ended ===
2015/11/22:16:46:53 Rodrigo RODRIGO Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2015/11/22:16:46:55 Rodrigo RODRIGO Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2015/11/22:16:46:55 Rodrigo RODRIGO PageOpen LaunchDialog
2015/11/22:16:47:03 Rodrigo RODRIGO PageOpen LicenseDialog
2015/11/22:16:47:03 Rodrigo RODRIGO PageOpen ProductInfoDialog
2015/11/22:16:47:03 Rodrigo RODRIGO PageOpen ProductSelectionDialog2
2015/11/22:16:47:24 Rodrigo RODRIGO PageOpen FullProgressDialog
2015/11/22:16:47:26 Rodrigo RODRIGO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:16:47:27 Rodrigo RODRIGO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2015/11/22:16:47:28 Rodrigo RODRIGO Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:47:28 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2015/11/22:16:47:28 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/11/22:16:47:29 Rodrigo RODRIGO Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2015/11/22:16:47:29 Rodrigo RODRIGO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2015/11/22:16:47:29 Rodrigo RODRIGO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/11/22:16:47:30 Rodrigo RODRIGO Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2015/11/22:16:47:30 Rodrigo RODRIGO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/22:16:47:33 Rodrigo RODRIGO Install DirectX® Runtime Succeeded
2015/11/22:16:47:34 Rodrigo RODRIGO Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:16:50:42 Rodrigo RODRIGO Download Aborted MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2015/11/22:16:50:42 Rodrigo RODRIGO Install Autodesk® Maya® 2016 Failed Download Failed, Installation aborted, Result=1603
2015/11/22:16:50:43 Rodrigo RODRIGO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2015/11/22:16:50:44 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/22:16:50:44 Rodrigo RODRIGO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Thanks!!
Message 138 of 281
dzanta
in reply to: DigoVargas
the error 1619 from your log files state they are not compatible so the installation failed.
you will need to uninstall all microsoft visual c++ files and .net files from your computer
reboot the computer
turn off anti-virus, anti-spyware, etc.
install the Maya software
after Maya installs, do a windows update for the updated C++ and .NET files
reboot
do a windows update again
start up Maya
activate and use
Message 139 of 281
Am gonan try my luck here too, as I'm getting frustrated that I just can't seem to figure out the root of my problem and nearly tried eerything I could find in the internet.
First of all, my problem started with the latest windows 10 update, it messed up A LOT of my programs, many giving me a generic error like 0xc000007b and stuff like that, though most of the programs got around that with a uninstal and reinstal. However my Autodesk programs give me more headaches than just the reinstalling.
First and foremost I can not uninstal it trough 'Programs and Features' and for some reason the unstalling process won't begin, but the uninstal tool from Autodesk it self works. So I did unstall it, clean uninstall and then redownload everything again and tried to install. But like most of the people here, mine also gives an installation failed error. After that max seems to be installed om my pc because when I restart the setup it says 3ds max is already installed but it's not showing up ANYWHERE on my computer and max files can't be opened either. So because of this I can't uninstall it or reinstall and I have to do a system restore, done 5 of those since last sunday.
I'll attach the error log of the latest try to this post but this is giving me migraines. I really dont know what to do anymore and I got an important deadline comming up next week. I am begging someone for help!
Regards.
Message 140 of 281
Getting some Autodesk software to function on Windows 10 is a bit difficult as most have seen.  In your situation, the best advice I can give to you based on everything you have tried is to restore the system back to a previous point in time using System Restore if that is possible.  If that is not possible, back up your data first, then do a complete restoration of your system (back to when you bought it).  If it is a DELL system, there will be an option to do this within a hidden partition on your hard drive.  Read your DELL documentation to do this.
If restoring your system back to that point is not feasible, use Windows Uninstall Tool to remove any/all Autodesk and other software you do not want on your system.  Then, restore they computer back to pre-Windows 10 if possible.  Then, install Autodesk software.
Hope this helps
Administrator Productivity
