I can't install any of the Autodesk programs from the Entertainment Creation Suite. I get error 1326.
Make sure your user is local Administrator and try the install again. Might even help to also right-click the setup.exe and run as Administrator.
I have used two different local Administrator accounts and I right clicked the setup.exe. I even changed my User Account Controls for both. I am still getting error 1326. Would installing the programs separately help solve the problem?
Yea there is still no fix for this problem. it appears their installer is garbage. for such an expensive software youd expect it to at least install. get it together!
@Anonymous This post is over 7 years old and there is a fix: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/error-1326-Error-getting-file-security.html
It's permissions related, if you need further support then reach out.
