Installation & Licensing
Installation error 1326
4 REPLIES 4
nvang11
1004 Views, 4 Replies
I can't install any of the Autodesk programs from the Entertainment Creation Suite. I get error 1326.
4 REPLIES 4
TravisNave
in reply to: nvang11
Make sure your user is local Administrator and try the install again.  Might even help to also right-click the setup.exe and run as Administrator.
Autodesk Forums:
nvang11
in reply to: TravisNave
I have used two different local Administrator accounts and I right clicked the setup.exe. I even changed my User Account Controls for both. I am still getting error 1326. Would installing the programs separately help solve the problem?
kizzzane
Yea there is still no fix for this problem. it appears their installer is garbage. for such an expensive software youd expect it to at least install.  get it together!
leowarren34
in reply to: kizzzane
@kizzzane This post is over 7 years old and there is a fix: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/error-1326-Error-getting...
It's permissions related, if you need further support then reach out.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Administrator Productivity
