Once user open the AutoCAD client and idle for 20 minutes, Is it possible to timeout the AutoCAD client after 20 minutes idle time.
Digambar Sasane
Solved by TravisNave. Go to Solution.
Solved by DarrenP. Go to Solution.
yea its called an options file:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
DarrenP
I recommend the minimum setting of TIMEOUTALL 900 (which is 15 minutes) for all instances. Because IDLE time is somewhat of a vague determination. Setting it at the minimum will give you the best results. See my adskflex.opt link in my signature for more information.
