Installation & Licensing
Client Timeout after 20 minutes idle
2 REPLIES 2
504 Views, 2 Replies
Once user open the AutoCAD client and idle for 20 minutes, Is it possible to timeout the AutoCAD client after 20 minutes idle time.
Digambar Sasane
2 REPLIES 2
DarrenP
yea its called an options file:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
DarrenP
TravisNave
I recommend the minimum setting of TIMEOUTALL 900 (which is 15 minutes) for all instances.  Because IDLE time is somewhat of a vague determination.  Setting it at the minimum will give you the best results.  See my adskflex.opt link in my signature for more information.
Autodesk Forums:
Administrator Productivity
