I woud like remove from my computer all items of APDSU2013 to clean before installing APDSU2014. What is the best way to do? Here is the link to the uninstal tool page for the version 2012, but...
- Is it this same for the version 2013?
- Is possible uninstall this software to clean (with registers of system)?
- Is it a good idea to completely remove the previous version?
Regards
Malenki
Solved by TravisNave. Go to Solution.
Both products will play nice together. I'd generally recommend that you install the new version first, to make sure that it actually installs and works without errors and that you can migrate your settings over from the previous release.
Otherwise, you can follow the clean uninstall procedure.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
