Installation & Licensing
Best way to clean Prod. Design Suite Ultimate 2013
1 REPLY 1
Malenki
362 Views, 1 Reply
I woud like remove from my computer all items of APDSU2013 to clean before installing APDSU2014. What is the best way to do? Here is the link to the uninstal tool page for the version 2012, but...
- Is it this same for the version 2013?
- Is possible uninstall this software to clean (with registers of system)?
- Is it a good idea to completely remove the previous version?
Regards
Malenki
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K CPU@3.70GHz + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
1 REPLY 1
TravisNave
in reply to: Malenki
Both products will play nice together.  I'd generally recommend that you install the new version first, to make sure that it actually installs and works without errors and that you can migrate your settings over from the previous release.
Otherwise, you can follow the clean uninstall procedure.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Autodesk Forums:
Administrator Productivity
