Autodesk Design Review 2013 Setup - Installation failed.
Message 1 of 13
I am on Windows 8 RTM x64. I am trying to install Design Review 2013, but the "internet connection" isn't being "found". My internet connection is fine. See the following:
Replies (12)
Message 2 of 13
TravisNave
Please be aware that Autodesk products are not yet supported on Windows 8.  You should look to see if you can find a full download if available.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 13
Thanks.
Re: "You should look to see if you can find a full download if available."
I wasn't able to...any chance you could point me in the right direction?
David
Message 4 of 13
dembkod
dcuccia,
Hello. This program is not supported on Windows 8, so it may not be usable in your environment. There is an alternate download method, however. I have a link for you hat describes this here:
http://upandready.typepad.com/up_and_ready/2012/04/design-review-download-now-vs-additional-install-...
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Message 5 of 13
@dembkod wrote:
dcuccia,
David Dembkoski
David - that worked perfectly. I'm up and running, thanks very much! -David
Message 6 of 13
sonablue
Hmm, but I'm getting the same error message... on a workstation that's WinXP 32-bit. I've tried the alternative download option as well. Any other ideas what I can do?
Thanks in advance.  ~Sona
Sona Greenberg
Message 7 of 13
dembkod
sonablue,
Hello. I would uninstall the program and wipe the residual folders for Design Review. There could be residual traces from a failed install.  First, run the MS Fixit utility and try to uninstall Design Review if it lists in this program.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Next, look for and delete residual traces that may be there. They will be clearly named and in a variety of places:
C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Program Files (x86)\Autodesk\
C:\Users\All Users\Autodesk\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
After all this is clean, make sure you have the MSI installer on your system.
http://www.microsoft.com/en-us/download/details.aspx?id=8483
Log in with an Admin account, turn off Windows UAC and Antivirus and give the install a go.
David Dembkoski
David Dembkoski
Message 8 of 13
sonablue
Hi dembkod,
Hmm, those look like folders in Win7, not WinXP. Nevertheless I'll look for their equivalent and clear what I find.
It's become less of a priority now that I've been switched to a Win7 machine myself (irony!), but a few other CAD users in my group are still using WinXP workstations and might like to see this resolved.
Sona Greenberg
Message 9 of 13
David-
This worked for me as well.  Thank you for your help!
Message 10 of 13
Hello
I am getting similar errors as shown in the images on the 1st post.   I am using 64 bit windows 7 and I am in a Corporate environment, not at home.  Is it a firewall or other security issue that is blocking me?   My internet connection is fine.  Here is what I downloaded and the error I get.  I tried version 2012 also, got same type of error.
Message 11 of 13
jessica.t
Hi @Anonymous and welcome to the community!
Will you try this posted solution and let me know if it resolves your issue? If not, please respond to this post with further details.
Thank you!
Jessica Thrasher
Message 12 of 13
it worked,  thank you ,  just download the BIG file and install,  seems to work fine
Message 13 of 13
jessica.t
You're welcome! Happy to help! Smiley Happy
Jessica Thrasher
