Trying to downlad and install 2015 LT on windows 8.1. Installation programme starts and tells me it is already installed, but i can find a trace of it on my machine.
Any ideas?
Solved by TravisNave. Go to Solution.
For information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-perform-a-clean-un...
For all other installation problems carefully consider using the Microsoft Installer Clean Up Utility at your own risk. For more information on this program, please thoroughly read my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
The Windows Install Clean Up worked great! I tried so many other options, including following the first link you sent, with an instruction sheet from Autodesk, but no use. The windows tool finally did the trick. Thank you!
