I have some problem with installation, and i can't solve it by myself.
This is the issue - I started to install http://img707.imageshack.us/img707/6905/installation1.jpg and after few seconds it shows this http://img688.imageshack.us/img688/7938/installation2.jpg
I even have nothing to clutch to fix it - none error msg or anything like that :<
Of course I tried to run Setup.exe file as administrator - without any changes.
Please feel free to ask for everything which can help You solve the problem.
Thanks in advance.
Pawel
Post the installation log file in that link.
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
i get the 1603 error as well but i dont know what a prerequisite is. There for cant uninstall it
A;right so if i have microsoft Visual C++ that is from 2005 i should uninstall it? You are the best dude.
The problem is .NET Framework 4.0. This could be failing if you are attempting to install on Windows 8 or Vista. Neither are supported. If you are on Win XP or Windows 7, simply uninstall the .NET 4 in your Control Panel > Programs. Then reinstall Max. If it still fails, you might need to manually install it and then remove the check for the prereq. Very difficult to do.
