Installation & Licensing
3ds Max 2013 Installation Problem
36 REPLIES 36
Message 1 of 37
6733 Views, 36 Replies
I have some problem with installation, and i can't solve it by myself.
This is the issue - I started to install  http://img707.imageshack.us/img707/6905/installation1.jpg and after few seconds it shows this http://img688.imageshack.us/img688/7938/installation2.jpg
I even have nothing to clutch to fix it - none error msg or anything like that :<
Of course I tried to run Setup.exe file as administrator - without any changes.
Please feel free to ask for everything which can help You solve the problem.
Thanks in advance.
Pawel
36 REPLIES 36
Message 2 of 37
TravisNave
Post the installation log file in that link.
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Message 3 of 37
in reply to: TravisNave
When i try to install 3ds Max after about 10 mins it fails to download in the middle of downloading. Any ideas? please help!!
Tags (3)
Message 4 of 37
TravisNave
Try downloading the trial.
Autodesk Forums:
Message 5 of 37
What is a prerequsite??
Message 6 of 37
i get the 1603 error as well but i dont know what a prerequisite is. There for cant uninstall it
Message 7 of 37
TravisNave
A program required to be installed before you can install the main
application.
Autodesk Forums:
Message 8 of 37
A;right so if i have microsoft Visual C++ that is from 2005 i should uninstall it? You are the best dude.
Message 9 of 37
TravisNave
Post your log file.
Autodesk Forums:
Message 10 of 37
Alirght let me find it
Message 11 of 37
TravisNave
Depends on where the failure is, my man. Your log file will state the
problematic version.
Autodesk Forums:
Message 12 of 37
Alright here it is
Message 13 of 37
your still here right? please dont leave!
Message 14 of 37
TravisNave
Yes. But I'm driving so I can't open the file right now. Gimme a few...
Autodesk Forums:
Message 15 of 37
=D Yeah. ill be waiting. Dont type and drive. Dangerous.
Message 16 of 37
TravisNave
The problem is .NET Framework 4.0.  This could be failing if you are attempting to install on Windows 8 or Vista.  Neither are supported.  If you are on Win XP or Windows 7, simply uninstall the .NET 4 in your Control Panel > Programs.  Then reinstall Max.  If it still fails, you might need to manually install it and then remove the check for the prereq.  Very difficult to do.
Autodesk Forums:
Message 17 of 37
Alright ill try that
Message 18 of 37
Im going to try and reinstall Max right now
Message 19 of 37
ok now im trying it my computer had to restart because of the .net 4.0 removal
Message 20 of 37
TravisNave
Sounds good.
Autodesk Forums:
Administrator Productivity
