I am running Windows 7 Professional 64-bit. We are on a domain. When I try to install AutoCAD 2011 on a user's computer the following error appears during the initialization of the install:
Here is the error that appears in the event viewer:
I have followed steps to set a software restriction policy (in the local policy) and still had the same results. I also moved the computer to a new OU that didn't inherit any policies from the domain and still could not get the install to run. I am out of ideas!! Any advice is appreciated.
Logged in as Administrator or equal during the install?
May have better luck in this Forum:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Continued here:
