Not able to install autodesk maya 2017
I'm not able to install the Autodesk Maya2017 application in my computer ,it's showing errors again and again.
Rob67ert
I think you should ask this in the https://forums.autodesk.com/t5/installation-licensing/bd-p/24 forum.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
TravisNave
Since it wasn't in the I&L forum, I had to randomly find it.  Without the installation log file, it is hard to determine why you are having a failure.  But as a guess, I suspect it is probably a download failure as that is the problem about 90% of the time.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
