Vault Basic2014 and Vault Server installed on PC and Files on network (Inventor)
Hello guys,
Is it possible to work with Vault Baisc 2014 and Vault Server Console both installed on my PC unit, yet our files are on network or should I install the virtual server (Autodesk Data Management Server Console 2014) on the network server instead?
If yes, how could I manage my files?
TravisNave
Install the ADMS on a server.  You access it via the Vault client on your computer.
https://knowledge.autodesk.com/support/vault-products
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
