Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel Grating stair treads & landing
4 REPLIES 4
Anima_mc
4428 Views, 4 Replies
How to create a steel stair with bar grating treads and landing in revit by using default stair family components?
4 REPLIES 4
hmunsell
in reply to: Anima_mc
Easiest way is to show a "Model" fill pattern (not Drafting) as the surface material.
Howard Munsell
Anima_mc
in reply to: hmunsell
Thank you for the reply. But  this is not the solution I was searching for. I'm seeking for a solution to model LOD 400 steel staircase with gratings.
hmunsell
you can apply a material to the Tread and Landing. in the material you can specify cutout pattern.
https://forums.autodesk.com/t5/revit-structure-forum/parametric-grating-family/td-p/9664483
Howard Munsell
ennujozlagam
https://www.revitcity.com/downloads.php?action=view&object_id=11263
https://www.nationalbimlibrary.com/en/industrial-floor-plates-and-stair-treads/carbon-steel-open-bar...
Forma Design Contest
Technology Administrators
