How to create a steel stair with bar grating treads and landing in revit by using default stair family components?
Solved by ennujozlagam. Go to Solution.
Solved by hmunsell. Go to Solution.
Easiest way is to show a "Model" fill pattern (not Drafting) as the surface material.
Howard Munsell
Thank you for the reply. But this is not the solution I was searching for. I'm seeking for a solution to model LOD 400 steel staircase with gratings.
you can apply a material to the Tread and Landing. in the material you can specify cutout pattern.
https://forums.autodesk.com/t5/revit-structure-forum/parametric-grating-family/td-p/9664483
Howard Munsell
https://www.revitcity.com/downloads.php?action=view&object_id=11263
