Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
array cut with void
6 REPLIES 6
EdwinG
3504 Views, 6 Replies
array cut with void
I have made a family of an element (generic model) which is loaded into another family that use this element as an array, now i want to cut only 1 of the element of the array with a void but this doesn't work not with a void in place and not with a loaded in to family void.
Has anybody another idea how i can do this.
6 REPLIES 6
in reply to: EdwinG
Use a face based void.
EdwinG
in reply to: ToanDN
@ToanDN
no doesn't work either.
in reply to: EdwinG
Really?
EdwinG
in reply to: ToanDN
@ToanDN
My bad,
Didn't cut fase based void before i loaded into my family, just draw it and i tried to cut after it loaded to my family.
thnks
in reply to: EdwinG
You cannot cut any instances in an array directly. You have to nest the array family in another family, associate the parameters so that you can flex the array, then you can cut it normally with a face based family.
daron.sperry
in reply to: ToanDN
I know this post is a few months old but I am looking to do the exact same thing.  Specifically, I am trying to put an array void form for a vision panel into one panel of a sectional door in order to create options for the number of vision panels.  The door panels are an array of a nested family.  When I downloaded your sample to analyze it I realized it is in Revit 2019.  Is there anyway I could recreate it in Revit 2018?  I tried to create the void in the door family directly but it does not cut into the panel of the array.  Thank you in advance.
Forma Design Contest
Technology Administrators
