I have made a family of an element (generic model) which is loaded into another family that use this element as an array, now i want to cut only 1 of the element of the array with a void but this doesn't work not with a void in place and not with a loaded in to family void.
Has anybody another idea how i can do this.
Solved by ToanDN. Go to Solution.
I know this post is a few months old but I am looking to do the exact same thing. Specifically, I am trying to put an array void form for a vision panel into one panel of a sectional door in order to create options for the number of vision panels. The door panels are an array of a nested family. When I downloaded your sample to analyze it I realized it is in Revit 2019. Is there anyway I could recreate it in Revit 2018? I tried to create the void in the door family directly but it does not cut into the panel of the array. Thank you in advance.
