Revit 2017 Installation Problem
I am trying to install Revit 2017 trial version since last night on windows 10 but i am facing error shown in the attached image again and again soon after the installation starts.
jasmin.gonzalez
Hi @Anonymous
Sorry about the issue you are facing.
Could you give this solution a try?
The issue happens when there are other products/prerequisites already installed.
Let me know if the solution works for you.
Jasmin Gonzalez
TravisNave
Install	Microsoft Visual C++ 2005 Redistributable (x64)	Failed	Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
I am trying to install microsoft visual c++2005 redistributable x64 manually but its not installing as shown in the attached image.
rudi.roux
Hi There,
HERE is a way in which you can install Visual C++ 2005 (x64) manually with your command prompt when receiving the 2381 error message.
Hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
rudi.roux
Hi @sajid.uett
I'm just following up to find out if you managed to resolve your installation issue.
If you resolved it, would you be so kind as to share your solution with the community for future reference?
Rudi Roux
LinkedIn
Guys None of the above solutions is working for me. I used AIDA to check but there is also a error while using it as shown in the attached image. please also see my latest attached log file as well.
