Tag Variable Thickness
When modeling low slop roofs and using the 'Modify Sub-Elements' on the roof to adjust the thickness of the variable layers within the roof when using tapered insulation it would be great to be able to tag the change in host thickness with a spot elevation that would display the change in thickness (ie +6").
