Shared Parameters in Elevation and Section Marks, Callout Heads and View Referen
39 Comments
wr.marshall
Thank you all for the suggestion to combine these Ideas!
@M-Alam  Thank you for you submission!
alessandrojb
Just an FYI for those waiting for this, there is a crazy silly workaround. You can (at least for callout heads) change the family category under [Modify>Properties>Family Category and Parameters] to something like view title, add the shared parameter, add a label with that shared parameter, copy the label with ctrl c, change the family category back to "Callout Heads", paste the label, and now it works...
Note if you do not copy paste the label, the "parameter name" will be reverted to Detail Number when you change the category back.
andy123491414
Observer
@alessandrojb
Hi There, I`m trying the callout head with your suggested method but it didn`t work for me. Can you explain further or shared your revit "call out" family? Thanks
robert_vanrij
Observer
I would like a simple Parameter of View Name to be added into Callouts...
Simple as that.
When using this workaround submitted by @Meelis123 , be sure that any applied view template doesn't block the editting of the parameter.
jmarshRBA3K
Unless the Revit code base is irresponsibly designed, this should be a 2 hour fix for them to add. 2016 to 2023 and counting.
stefanl1234
Upvoting this important request, but adding one comment,
The shared parameters ought to be able to link "Sheets" (just like the referencing sheet number) not just "View"
KyleR13
2023 still not available.  🙁
cprettyman
The composite number of votes for this concept, from all the separate "ideas" in the 1st post seems like it would give this some priority.  I know that votes, alone, do not determine whether or not ADSK accepts an idea.  But, it influences it, and this one clearly has community support.
Not yet available in Revit 2023
 Shared Parameters for Elevation Mark, Section Mark, Callout Head & View Reference Families.
not urgent, but would be nice to have that!
psingh96SFR
Hi, we require this to be flexible parameter like others.
Autodesk please enable this.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
Supporting this idea in 2024
2025 and still not available
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | View Reference Enhancements | Autodesk
 -The Factory
Thanks Factory!
It does not seem to work in Revit 2026. It allows to add the shared parameter but it's greyed out in a project.
