Hi, thanks for responding.
I have attached a shot of my company's title block design, and a few other things for some explanation on this...
In order to achieve the title block design, I had to create a shared parameter "sheet letter" in our template file for this to work. I have added it to our title block family, our sheet index shcedule and our project browser for clear organization.
My problem is: our elevation, section and detail tags refer to sheet number only. This is bad because in our sets we will have an A2.1, S2.1, E2.1, ect. I need the the elevation, section and detail tags to know what the "sheet letter" is as well as the sheet number.
I know it is not possible to add a shared parameter into these tags....but there is always a workaround. I need to figure out the workaround that will still make the tags automatically fill out...
What do you think?
