Hi All,
I have searched the ideas on this page and have found this idea suggested numerous times with no response from Autodesk. I decided to re-post the idea to hopefully get a response....
For me this is the most annoying thing in Revit! I am a structural Draftsperson and i would normally cut 100's of sections a project, 99% of these sections would have a final far clip offset off 100mm max. When i create the section i get all sort of far clip offsets, some are 100+ Meters!? Very Very annoying, either zooming out to drag the clip in or going to the properties and changing there, also the large clip area slows down the process as Revit needs to account for all the elements in the clip. The addition of a default option for all sections would be very handy and/or the option to set the clip before you finish placing the section.
Please vote for this idea if you agree and hopefully it will be taken on board by Autodesk.
Shane
