Reveal Hidden Elements without links
When selecting "Reveal Hidden Elements", all hidden elements are shown, even hidden elements in linked Revit files. This is sometimes ok, but when there are a lot of links loaded the process can be very slow, and very messy. This makes it really hard to find the element you are looking to unhide.
If there was a button for "Reveal Hidden Elements - Without Links" that would mean that only elements hidden in the current Revit file would be displayed, improving efficiency by increasing speed and clarity.
1 Comment
Ric_Weber
Color coding would be good for all the different ways something can be hidden...  but in addition to that or even more importantly would be a Filter system of those hidden items you've revealed with the Reveal Hidden Elements tool.
As @jkidder said, currently we select Reveal Hidden Elements and it shows (nearly) everything that is hidden in a multitude of ways.  If I have items temporarily hidden those appear in blue, other items hidden regardless of method are in pink.  If there have been a lot of things hidden in various ways, all of those items make it nearly impossible to find what you are looking for.
Recommended workflow: Select Reveal Hidden Elements, each of the different methods of hiding an element are color coded, a Filter list appears (default to last used) where we can choose from the following list of hiding methods we want shown (one, several, or all).  The list would separate items by the method used to hide:
Element  https://forums.autodesk.com/t5/revit-ideas/visually-differentiate-manually-hidden-elements-from-hidd...
Model Category
Annotation Category
Analytical Model Category
Imported Category
View Filter https://forums.autodesk.com/t5/revit-ideas/reveal-hidden-elements-shows-objects-hidden-by-a-filter-i...
Workset
Link (entire link turned off)
Category by Link  https://forums.autodesk.com/t5/revit-ideas/reveal-hidden-elements-without-links/idi-p/13342181
Temporary https://forums.autodesk.com/t5/revit-ideas/quot-reveal-element-s-quot-in-temporary-hide-isolate-tool...
Revision Cloud/Tags(based on the Sheet Issues/Revisions dialog)  https://forums.autodesk.com/t5/revit-ideas/reveal-hidden-elements-should-include/idi-p/13823590
Detail Level https://forums.autodesk.com/t5/revit-ideas/reveal-hidden-elements-regardless-of-detail-level/idi-p/7...
In general this would solve these ideas as well I believe:
https://forums.autodesk.com/t5/revit-ideas/change-the-way-reveal-hidden-displays-horizontal-elements...
https://forums.autodesk.com/t5/revit-ideas/reveal-hidden-amp-visibility/idi-p/8346144
https://forums.autodesk.com/t5/revit-ideas/only-show-hidden-elements-in-reveal-hidden-elements-mode/...
https://forums.autodesk.com/t5/revit-ideas/hidden-element-navigator/idi-p/8298399
https://forums.autodesk.com/t5/revit-ideas/quick-way-to-find-out-why-an-element-is-hidden/idi-p/7808...
Since the elements hidden by Element are the most pertinent to find, in addition to the above, a number on the lightbulb icon (perhaps the number is enlarged on mouse over?) that reflects the number of items hidden by Element.  This would solve these ideas:
https://forums.autodesk.com/t5/revit-ideas/hidden-elements-in-this-view-icon/idi-p/13079617
https://forums.autodesk.com/t5/revit-ideas/put-number-next-to-view-tab-title-showing-number-of-eleme...
