This idea has been created on the behalf of user from a French company.
The idea would be to enable the possibility to define relative paths when linking point clouds in REVIT.
Relatives paths can be defined for linked REVIT, CAD and IFC files but not for point clouds.
This can be problematic for complex project for which multiple points clouds are necessary.
When such files are shared outside of the office, users needs to manually redefine correct absolute paths to the points clouds files.
Relative paths missing for points clouds files
Currently the workaround is to make sure that every users place the points clouds in the same location defined in REVIT option (“File location” / “Root path for point clouds”).
File location in REVIT options
