Record and Run Actions
If you've ever worked with photoshop you are familiar with the 'Actions' , I hit the record and do a task.
Then instead of working with dynamo, Macro, Journal Logs, Visual Studio and So on; All i do is Running that Recorded Action 🙂
7 Comments
Loads of other software have Macro record functions, to automate repetitive actions that are required. why doesn't Revit do this to help speed up these mundane tasks?
GHASEM_ARIYANI
Added tools such as Action record AutoCAD For Revit.
Or similar features repetitive tasks and save on all our projects.
yavork
YZhuang_Spectech
Currently, they have fancy keyboards and mice out there that allow you to press a button (to activate this tool), do something like create a sheet, then press the button again to deactivate the tool.
This tool then remembers the exact key strokes you pressed, and will continue to duplicate those keystrokes as long as its the last saved command. This allows for quick placement of lots of things.
For example, we currently have families that require 2-3 different tags, then based on how many tags are needed for that item, some moving is needed of the tags to clean them up so there is no overlapping. Using my keystroke keyboard, I press the button to activate the tool and then: I place my family, tag it 2-3 times, move the tags to their correct positioning, then finish of by pressing the keystroke button again so it saves those commands.
Now when i go to place my next identical family, i just need to left-click with my mouse, and it automatically remembers all the keystrokes above. This then automatically places my family, tags, and moves tags to their correct position that I placed them in saving me a ton of time seeing as we can have up to 60-70 of these particular families in a given project.
This then leads to saving me LOADS of time throughout the year. If Revit had a button that remembered your keystrokes in the same way, im sure there are MANY different repetitive functions that can make use of such a function rather than spending 100-200$ on the required mouse/keyboard that does this.
i wonder how is this still not a thing when they even implemented it to autocad already. Shame revit developers.
Clntnco
That is a great Idea, but the action should be in a format that can be opened in an editor like vba, vb, c+, or python. The ultimate would be the ability to choose which language the user prefers.
ovis.mae
@Clntnco what I just described is the ultimate idea 😅 for started It would be great to record my actions and just see the functional code behind it! I've been stucked in many situations in which I didn't know what is the perfectly code for what I have in mind, and I couldn't find any easy solution or answer on the web!
