Currently, to print a schedule, you must first create a sheet and place the schedule on the sheet. We use a lot of schedules to check various elements, parameters, etc. It would be great to be able to print a schedule without having to first place it on a sheet. Sure, you can make a generic sheet and just swap out schedules whenever you want to print one, but it's just a bunch of extra steps.
Right now I'm updating the View on Sheet parameter for all my details. I have to use the same naming conventions for two buildings that are modeled in separate revit files. It would be great to be able to just PDF the schedule with View on Sheet and View Names, for quick reference when working in the second building. This is just one example of many uses for print/PDF'ing schedules without having to place them on sheets.
