Prevent sheets to pick up the scale of legend views
It is a very common rookie mistake to get the sheet scale read 'As indicated' once they drop a legend on it.
It would be so much easier if legends had the option to not report their scale to the sheet.
25 Comments
lionel.kai
Great idea! Previously, I was thinking globally:
http://forums.autodesk.com/t5/revit-ideas/revit-default-manager/idc-p/6377990#M1019
or per-sheet:
http://forums.autodesk.com/t5/revit-ideas/custom-text-in-scale-parameter/idc-p/6377987#M1018
but checking a "Do not report Scale to Sheet" option in the Legend's Properties or Custom Scale dialog makes a lot more sense. That way, if you want the scale of some Legends to show up, but not others, you have that flexibility.
It will be helpful if all views had this parameter so that we could make key plans without having the scale as "as indicated".
Kevin.Bell
If a Legend is placed on a sheet with a floor plan and the scales do not match Revit displays 'As Indicated' in the titleblocks scale.
Often Legends do not require a scale.
I'd like the option to select 'No Scale' for a Legend so that when its placed on a sheet with a plan its scale is ignored and the titleblock only shows the Plans scale.
Inerin
There should be an options to turn the scale associated with legend off. If we have a sheet with a 1:100 scale and another with a 1:50 scale, we end up having to make to legends with the same text only in different scales. I would be better if we could use one legend on all sheets which won't affect the scale noted on the titleblock.
Tags (2)
I agree! It would be amazing! and plans should have the same "not scale" parameter in order to make key plans and don't afect the scale indicated in the titleblock!
Claire_L_G
this thread started in 2016 - autodesk sort it please,  its still an issue in Revit 2021
matthewsantana
Still an issue in 2022..
MOR-ConorMacken
As a related topic, it would also be useful if "As Indicated" could be customised to something else (we normally use "As Shown" or "A/S" on CAD drawings) .
Better still it could list the scales, E.g. "1:100, 50, 20" with an upper limit to stop the list being too long after which it would fall back on the catch-all text.
jameshowellsLKN7T
Still remains an issue
mbXL3F3
Can't believe Autodesk still could not fix this simple issue...
ckilger12
Bumping this back up....the fact we still have to deal with this is crazy. We have standardized on creating options in our titleblock to control this
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
DanielKP2Z9V
Glad to hear that it has been accepted to the roadmap, is there a link available somewhere to track its progress? I've searched the public roadmap for "legend" "scale", "title" and "label", but nothing popped up.
Claire_L_G
Not to my knowledge....
DanielKP2Z9V
I've ended up using a custom global/shared parameter that is referenced by a label in a titleblock - however it soon became obvious that changing a scale for hundreds of sheets will become very errorprone. I wrote a script which sets a chose parameter from chosen sheets based on placed views - any view except a legend. It prints at the end list of sheets for which scale couldn't be determined (most likely because there were multiple views with different scales): using Autodesk.Revit.Attributes;using Autodesk.Revit.DB;using Autodesk.Revit - Pastebin.com (code is incomplete, this is just a reference, I will try to publish the whole thing soon).
A problem lasts over 10 years since the start of Revit
This makes me question those who use CAD, or even older, handmade the drawings: who made the "brilliant" idea to include the scales in the titleblock?
When you have a drawing with a plan view and some detailed callouts with different scales for more detail of some parts, would you look at the view names or the titleblock to find the scale of EACH specific view?
DanielKP2Z9V
Sorry to hear that, I've been there. This sucks.
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Title Block Scale Override | Autodesk
 -The Factory
Apologies...after further discussion, while possible in Revit 2026 to create an override for the title block scale text, this feature does not directly prevent the sheet scale from recognizing the legend scale et. al.
