plot stamp
plot stamp
please add more features to use as plot stamp like the username who printing the sheets, computer name we plotting from, Revit version
of course I need this parameters to read automatically
5 Comments
dplumb_BWBR
And the "File Name" should point to the Central File, NOT the Local Copy
The plot stamp should be a text format string (think number formats in Excel or fields in Word) that allows us to piece together the text we want. I would suggest the following components:
Date and time, the usual DD/MM/YYYY H:mm type string so we can do things like D MMM YYYY to get text that is unambiguious when working internationally or YYMMDD a for compact code.
Filename, with central, local, drive, path and extension all as parameters, must be able to trim path to a fixed length with option to trim at start, end or middle of string and use ellipsis (e.g. middle trim would be C:\proj...\12345\model\)
PC Username and/or Autodesk user of person printing
Print sheet size (e.g. A1, A3)
dplumb_BWBR
Taking a wider view, dates should be formatted any way you want - as a parameter
https://forums.autodesk.com/t5/revit-ideas/quot-date-quot-parameter-type/idi-p/6323051
of course we need to format date/time stamp as we want
maybe I want to show date with out time
there is a big need to add automatic data while printing
I hope Autodesk to pay attention to that
lionel.kai
Especially needed since I just discovered that BIM360 doesn't append the user name to local files...
see also: "Central File Path" and "User Name" parameters for Labels in Titleblocks
