Pipe Insulation on Plumbing Discipline
When applying pipe insulation to pipes, with the view on Plumbing Discipline the pipes are not visible thru the pipe insulation....but the pipe fittings are! To make the pipes visible we must change our view to Coordination, ruining the correct way to show pipes in a piping plan just so we can show the pipe insulation.
-Transparency does not allow the pipes to show under the insulation
-Filter to make pipes linetype different does not show pipes under insulation
-Halftone on Pipe Insulation does not make pipes under insulation visible
Coordination Discipline
Plumbing Discipline
Why does the pipe disappear on the plans we really need it to show on??
1 Comment
Thierry.A
No problem here Revit 2021 (except axis line...)
