Rotation Parameter
Rotation Parameter
Adding the ability to set a parameter value for the angle at which something would be rotated from its original position would be very helpful (using the rotate tool) similar to the way the array parameters are set up. Instead to do this you have to set multiple reference planes and use parameters to rotate them and use a loaded child family that is aligned to a certain rotating plane.
1 Comment
mhiserZFHXS
I'm confused as to what exactly you're asking for. Are you talking specifically about rotating a nested family? And are you saying to do this with the rotate tool, or similar to how the rotate tool functions?
