Currently up to Revit 2021, Phase Filters must be named IDENTICALLY between all models linked in a project for the Phases & Phase Graphic Overrides to apply/override to elements. Can Autodesk make the Phase Filter Names a local item, and not a workshared item that pulls between models?
If the Phase Filter names do not match the linked models it negates all overrides done by that Phase Filter onto the conflicting Linked models. For example all of our In-House models wish to use more intuitive Phase Filter naming as opposed to the OOTB names. We like rename our Phase Filter Names to 'Demolition Plans', 'Existing Views', 'New Construction Plans'...etc. But when we work with outside consultants none of our Phase Filters apply to the consultant's model(s) because the names do not match.
Phase Filters are relative to the Phase of the applied view, not relying on the linked model(s) to share their Phase Filter Names, only their Phase Created/Phase Demolished.
In summary; the Phase Filter Names are over-constrained between linked models and it would be helpful for this excessive constraint to be removed.
