Panel Schedules export to A4 PDF
Can you please add a feature allowing Panel Schedules to be exported to PDF A4 paper size, please.
It is ridiculous that we need to create separate sheets and drag and drop the schedules into it. Plus there is no way to make sure it will fit on A4 paper size, so you have to create a new sheet template for each DB size type. It is much unnecessary work which should be avoided.
Alternatively, you could create a feature where upon creation DB schedule the sheet is automatically created with the DB chart inserted and named the same as the Panel Name
1 Comment
Is think that function you need may be covered by reports that is in the app store. At least that is how we export our schedules to A4 and A3 formats.
