Republishining an archived amazing sugestion by jkidder.
There is no way to do this as yet, and it would be a very useful feacture.~~
It would be helpful for presentations for there to be a way to easily apply different model display styles and material overrides to different filter sets. For example:
Having the option to manipulate the model display style via filter and apply a material via filter would provide a range of creating graphic options. Currently there isn't an easy way to get the views described, and some are impossible due to angles and overlaps. The stacking of multiple views, complicated work arounds with phase filters (which usually have to be temporary) or exporting the view into another program are our only options. If a view has to be exported to Photoshop or similar we loose the ability to quickly iterate through concepts in a desired view style."
Original tread link: https://forums.autodesk.com/t5/revit-ideas/model-display-style-and-material-overrides-applied-via-fi...
Now let me add my need to the pool:
- Create a filter to diferenciate existing trees from topography survey from existing contextual vegetation, in 3D shading (and proposed ones too while we are at it).
