Make the Select Previous command actually Select the Previous Elements
The Select Previous command in the right-click menu is a joke. It doesn't work all of the time as one would expect. Most of the time when I select an element(s) to run a command, but the command gets fouled by user error, wrong key board short-cut, etc., and I hit Select Previous to select the previous elements and run the command again, the command will not be available. PLEASE!!! Make it actually work.
