Make the Select Previous command actually Select the Previous Elements
The Select Previous command in the right-click menu is a joke. It doesn't work all of the time as one would expect. Most of the time when I select an element(s) to run a command, but the command gets fouled by user error, wrong key board short-cut, etc., and I hit Select Previous to select the previous elements and run the command again, the command will not be available. PLEASE!!! Make it actually work.
2 Comments
mpukas
I'm bumping this thread to hopefully get some traction.
Ric_Weber
It is interesting why sometimes it works and sometimes it doesn't...  seems most times it doesn't for me.  I'm not sure if I'm doing something wrong or what, but I'm not seeing any rhyme or reason as to when it does work or when it doesn't work.
