This idea is split out from this post.
There are a few commercial/industrial electrical elements I'm finding myself constantly struggling to replicate in the MEP system, and I think they could potentially be incorporated as new Revit Electrical Equipment types. If not, I'd at least like to bring them to the developer's attention so they see the pain points we are encountering.
"Transformer and Panel" - This would be a combination of a transformer feeding an electrical panel. So it would have a primary and secondary distribution system like a transformer, but it would also allow you to produce a panel schedule.
Alternatively, this could be solved by allowing nested electrical equipment to be pre-circuited internally. That would be a better solution since you could then use it to model entire substations as well, with a primary disconnect, a transformer, and multiple secondary compartments represented by a panel schedule. You could even use it to model transfer switches with built-in protective devices.
