I use different types of Sections, one of which I call Working Sections. I move these Sections as needed when I designing and documenting. But when using Design Options, Sections can't be moved. You can double click the Section Head to go to that view. As I'm designing in Design Options, when I want to look at a different part of the building, I have to exit the Design Option, so I can move the Section, then go back into the Design Option to continue. It's disruptive to work flow and thought process. Like so many things in Revit... It would be extremely useful to be able to move Sections while using Design Options.
