Make API Methods for Split, Split With Gap
Currently Split/Split With Gap are only enumeration members (they cannot be used in a script).  I would like to be able to have a command that is something like Element.Split(plane)  where you could specify a plane (or point) at which to split the specified element.
Example use case would be splitting columns - if I wanted to split columns using the API, i actually have to create many copies of the column, then adjust the top/bottom of each column to achieve what could be accomplished with Split.
10 Comments
boostyourbim
this should also allow splitting walls with the same functionality as in the API (https://forums.autodesk.com/t5/revit-api-forum/split-wall-using-revit-api/td-p/6562014)
Creating many copies of column and adjusting top and bottom levels is the way I'm using but it works on vertical columns only.
I encountered problem when the column is slanted. Is there a way to use the Split feature?
jeremytammik
Raised a development issue for this:  CF-4916 [API wish: split wall like 'Split with gap' -- 14929026].
Also discussed in
https://forums.autodesk.com/t5/revit-api-forum/split-wall/m-p/8660986
hiroe.katano
Spilt Walls cannot be automated because there is no Split Element in API. I strongly request to implement Split Element in Revit API.
Tags (2)
Status changed to: Gathering Support
Hi, @hiroe.katano ,
Here is a similar Idea...feel free to add your votes there, too. If you like, I can combine your post with this one.
Make API Methods for Split, Split With Gap - Autodesk Community
Thank you for your submission!
-Kimberly
jeremy_tammik
Further discussion on this topic in this thread:
dvd_gnz
6 years in and this is still very much needed. Splitting walls manually in a robust way is still very challenging. We shouldn't have to manually relocate each hosted family instance, copy parameters, etc.
The logic is clearly already there since the UI command to split walls works well. Why can't this just be exposed to the API?
NimeshJ
Even after 7 years this is not yet fixed, you still cannot use the Split Method on walls.
We still have to create new walls instead of simply adding Spilt to them.
valensas_balsevicius1
lol...I am happy I wasted only few minutes before I found this thread. It means we will have to wait a few more years.
PieterL_TM
I really need this! currently I have scripts that will never work unless we have this functionality
edit: Gathering support in 2021? Autodesk... please. just. get. it. done.
