Split Wall using Revit API
Hope you are doing great. I would like to ask you a question regarding splitting the wall.
Question:
I have a wall and have to split it using Revit API. I have placement points as an input and need to split the wall based on those points. Do we have any command to achieve this using Revit API?
Your help would be greatly appreciated!
Thanks in advance,
Jyoti
Jyoti,
Revit doesn't come with any type of intersect or split elements. I have something started. You can find the code here:
https://github.com/chhadidg/EditElements
It works so far for the beams. I didn't have time to finish this. Maybe one day. Feel free to use the code.
regards
Christian
jeremytammik
Dear Jyoti,
What do you mean by split wall? You can split certain family instances, such as beams, columns, etc. using the FamilyInstance.Split method. That does not apply to walls, however. You can split faces on a wall to apply different materials. For that, please refer to the FaceSplitter class.
Cheers,
Jeremy
c.f. http://stackoverflow.com/questions/39494159/split-wall-using-revit-api/39506899#39506899
Jeremy Tammik
Developer Technical Services
The Building Coder
I still think for walls you would need to generate the new placement lines for the walls.
Hi Jeremy,
I want to implement a functionality similar  to "Split with Gap" tool which we have in Revit 2015. Please let me know how to use this tool/implement it's functionality using Revit 2015 API.
Jyoti
boostyourbim
jeremy_tammik
Further discussion on this topic in this thread:
