Line spacing Parameter for Text Nodes in Revit
An additional Parameter to change line spacing for Text Nodes in Revit would be very helpful.
The current functionality of text properties gives the possibility to control the Width Factor however, there is no corresponding parameter for the line spaces.
The needed functionality would be additional parameter to control the spacing between lines, as in the image below:
14 Comments
Hi, @karolina_kordula ,
Here are several similar Ideas that could be combined with this one:
Text Note Spacing - Autodesk Community
Text Editor - Autodesk Community
Revit's Text Editor Needs To Be At Least As Good As AutoCAD's - Autodesk Community
Thank you for the submission!
Kimberly
lpendergraft
This would be wonderful! Please, Autodesk!
elina.hyvamaki
Yes, and a line spacing parameter would be really useful in labels (of tags and title blocks) also, thanks!
mcgairlie
Observer
I am experiencing the same issue with the inability to change the text line spacing in notes etc.
Please Autodesk fix this one.
PS while I'm here can you make Revit and AutoCAD one program?
'RevCAD'
Tom_Fitz
2 years in and no progress on this basic text function.
Not having line spacing control is especially difficult when using a font with 2 languages, especially an Asian language. When I use Japanese characters the space between lines isn't slightly off it is nearly double which makes is impossible to allow putting Japanese characters into a label with multiple lines, for example a sheet title.
Please address this issue.
nermin_hadziomerovic
hello,
I fully agree with Misses Kordula. It wold be really helpful for big projects.
merci d'avance 🙂
mcloughlinohana
Yes, totally agree, getting line spacing to be editable would be very nice!
Erikdlr
One way to "cheat" a line spacing into a text note:
set the text to superscript or subscript..see screenshot
You're gonna have to try harder than that to stop basic line spacing, autodesk!!
adr79
Am using Revit 2025. Inability to adjust text spacing is creating havoc in presentation, especially general notes. Hoping this is dealt with in Revit 2026.
Ric_Weber
@kimberly_fuhrman-jones   here's another one that should be combined with this idea:
https://forums.autodesk.com/t5/revit-ideas/line-spacing-in-text/idi-p/12920822
Yes, please improve text editor for revit, An additional Parameter to change line spacing for Text Nodes in Revit would be very helpful.
kealder
Observer
It is really frustrating that AutoDesk does not listen to user input on something as basic as this. I feel like I'm using Wordperfect back in the 1990's every time I have to deal with text, and trying to make lists and on-sheet specs legible.
dotsu.sasaburo.au
文字やタグで改行をした際に文字の行間を狭める、もしくは調整できるようにしていただきたいです。
行間が広く、限られた図面のスペースを多くとられてしまいます。
図面の体裁も整いにくく、困っているとの声も多いです。
行間が調整できるととても助かります。是非よろしくお願いいたします。
Note from Community Manager: This is the original Japanese idea submitted by the author. Autodesk translated and reposted it to the English Revit Ideas board.
yuki.scharf
Adjust Line Spacing for Text and Tags
Description:
I would like to request the ability to adjust line spacing for text and tags in Revit.
When text notes or tags contain line breaks, the current line spacing is often too wide. This causes the text or tag to take up too much space on drawings, especially in limited drawing areas.
Because the line spacing cannot currently be adjusted, it can be difficult to maintain a clean and well-organized drawing layout. We have heard similar feedback from many users who struggle with this issue in their daily documentation work.
Request:
Please add a setting that allows users to reduce or adjust the line spacing for multi-line text and tags.
Suggested implementation:
Add a parameter such as Line Spacing or Line Spacing at Line Breaks to the Text and Tag settings, so users can control the spacing between lines.
This improvement would help users create more compact, readable, and better-formatted drawings.
Reference:
This request was originally posted in Revit Ideas Japanese Forum. Since this is an important request from Japanese Revit users and was evaluated by the Revit User Group in 2025, I am reposting it here for broader visibility.
Original Japanese Revit Ideas post:
https://forums.autodesk.com/t5/revit-aidia-ri-ben-yuforamu/wen-zino-xing-jianwo-diao-zhengdekiruyoun...
Thank you for considering this request.
