Import SAT newer than version 7
Current Autodesk Products (AutoCad, Civil 3D, Revit) can not import SAT-files newer than version 7.
I t would be nice if the SAT-import was updated along with the development of the format.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
4 Comments
dgorsman
I don't think that anything past that version is openly available.  If the owner (Dassault, I think, based on this) isn't willing to share the specification there isn't much anyone else can do.
magne.ganz
Good point. Is that the case? Later versions of sat are not open for other developers?
tim.perkinsSHINE
Currently I have 100's of files that have to be converted from Solidworks to .sat in order for us to link into Revit 2021. Having the ability to link a .sat newer than version 7.0 will simplify out ability to link the files efficiently. If Dessault has versions newer that 7.0 available, I would think other developers would have newer versions available. We also receive Solidworks files from several manuafacturer's that we have to link into Revit also. Each time we receive an updated file, we have to make sure we can export from SW to version 7.0 in order to use in Revit. Please make newer version of .sat available/readable in Autodesk software.
Ich stehe aktuell auch vor dem Problem, das alle .sat Dateien in Version 7.0 oder älter konvertiert werden müssen und verstehe nicht, weshalb Autodesk Revit gegenüber anderen Anbietern am Markt mit so rückschrittlicher Software arbeite. es wäre eine Große Arbeitserleichterung, wenn man nicht mit einem Zweitprogramm erst alles auf den Stand von Version 7.0 zurücksetzen müsste.
