Custom Round Duct - Routing Solutions
Revit really has to do a better job with its Routing Solutions.
#1 - Common sense dictates that Routing Solutions should be managed by user-defined Routing Preferences.  If I set my Routing Preferences to only use 15-degree increments for fittings, then a 34.06-degree elbow should not be a part of any routing solution.  This would cut down on many of the silly solutions that are generated.
#2 - If #1 cannot be accomplished for some reason, then I should be able to place what elbows I need, align the open ends of the elbows, and count on Routing Solutions to competently connect those two elbows with a straight piece of duct.
There are simply too many possibilities to be efficient.  And most times none of the solutions work.  I believe these two things could help.
Let's do better with this potentially wonderful, but currently dreadful, feature.
1 Comment
Status changed to: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months and as such we will not be pursuing it at this time. Please feel free to re-word (titles and clear descriptions are very important) and resubmit this Idea.
