Fix hatch pattern for slope floor!
This has been a problem for years!
When the floor is sloped, the pattern get's all wonky. Placing a filled region on top is a dumb way of doing it, if the profile change, you have to go update all the filled regions. We prefer to use the live model and not put a band-aid on top.
Autodesk please fix!!
51 Comments
YES PLEASE!!  Countless reasons why this is necessary.  I have had to make too many filled regions as a band-aid to this issue
Intuos5
In general there is a need for UV mapping patterns to curved objects and also to terrain.
rbarbosa8DQGJ
We also need a way to create hatch patterns in sheets, for little annotations, such as key plan.
Simon_Weel
Something similar with patterns on stairs-treads. If a tread is, for example, trapezoid-shaped, the surface pattern aligns with one of the sides instead of perpendicular to the nosing line....
christopher_holden
YES.
For crying out loud Autodesk, just fix your products will you? I consider this to be basic functionality that is broken not an additional feature request.
It should be possible to correctly align model hatch patterns on floors with modified subelements. This is essential for all external works and any internal floor with a fall on it - the arbitrary hatch alignment that appears when sub elements are modified is BROKEN since it was not explicitly set by the user and cannot be changed.
christopher_holden
"We also need a way to create hatch patterns in sheets, for little annotations, such as key plan."
@rbarbosa8DQGJ
You should use filled regions in a Legend View for Keys which can be placed on multiple sheets. But...
This is yet more broken stuff. If the floor family legend view worked correctly we would be able to drop floors into a legend view and set the view to something other than Section, ie: Plan, like doors and other family categories, which would then show the surface hatch patterns for a key directly. Sigh.
amir.amgad
This is a very huge FLAW in revit especially for those trying to use this program for LANDSCAPE!! I have been battling with this issue for 6 years doing filled regions on top of floors which is double work and it hides Trees and Site furniture!! You really have to fix this AS SOON AS POSSIBLE!!!
kimberly.fuhrman
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
pieter4
@kimberly.fuhrman  has a decision been made on whether this fix will be targeted to drafting or model patterns?
kimberly.fuhrman
Hi, @pieter4 ,
As of right now, it hasn't been decided. Feedback would be most welcomed here and in the Preview Release.
Thank you!
Kimberly
Ra-X
Strong +1 to curing the pattern distortions
MDAVIS_MKSK
PLEASE FIX!!!! This would be great to add in a hotfix for 2022. No need to wait, since we have been needing this feature since at least 2010.
This is currently the biggest problem for plan documentation. At my new firm where autocad is the lifeline, they cannot fathom how a hatch isn't able to project flat. Filters are also worthless if you have floors that slope. The filter hatch overrides still end up distorted. We then have to resort to filled regions in our plans to correct the distorted hatches. This is true for simple ramps to more complex forms. Using filled regions is not a reasonable workaround. Geometries change then all plans need to be updated accordingly. This is a huge time waster and pretty much feels like we are drawing hatched plans in autocad. Efficiency is definitely lost due to this issue. In 3D views I understand that the hatch would show distorted, but in 2D views used for documentation a distorted hatch pattern can cause confusion or misreading by the contractor!!!
My suggeted fix (as an architect who does a lot of landscape architecture as well)
We need a need 'Paving' modelling category which has similar behaviour to floors, however unlike floors the new category understands that block paving or paving slabs have a degree of flexibility so that it can fall in multiple directions without distorting beyond beleif. The top 'paved' layer needs to drape over the shape of the of the paving slab without a load of tridangulations and warped curves.
This functionality needs to be beyond just the hatch pattern it also needs to extend to the material as well such that the material doesn't distort in renders.
In an ideal world this new 'paving' category would have 'pad' functionality built into the underside of the material such that topography would build up (or cut down) to the underside of the 'paving' build up, saves having to put a pad to the underside of each paving slab.
Please please make this happen!
jagostinho74
Would suggest adding a control to Fill Pattern orientation in a similar manner than the "Span Direction.
neil_vero
Observer
Is there any update if this has been added to 2021 or 2022?
kimberly.fuhrman
Hi, @neil_vero ,
According to this item on the Revit Public Roadmap, this Idea is still under development. Stay tuned!
Kimberly
MDAVIS_MKSK
Any status update on this issue?
I've been hoping this would get fixed since I started working in revit in 2011! Some plan sets involve a lot of manual work and subsequent updates due to the need to draw filled regions where the hatch patterns display warped in plan. It's the biggest complaint from across my firm.... People migrating from cad use it as a case against revit since it adds a lot of time to documentation and adds the unnecessary task of managing filled regions across multiple views when model geometry changes. It would be great to shut them up! 🙂
kimberly.fuhrman
Hi, @MDAVIS_MKSK ,
It is still on the roadmap, and thus still in development. Other than that we really cannot say 'when' it might be implemented. You can also join the Revit Preview Release to follow feature development there. Sorry I can't be of more help!
-Kimberly
W_Whit
Hi @kimberly.fuhrman
Can you confirm this function was not released as part of Revit  2023?
Hopefully, I am wrong and just haven't been able to turn it on?
Ra-X
I second Will, please confirm this hasn't been addressed - after... I don't know... a good bit over a decade of asking? - in the current version.
Forma Design Contest
Technology Administrators
