Filled region always defaults to straight lines (implement memory for last used line style)
I'm sure others have requested this but the filled region tool box doesn't remember your last used line style.
Can we make this happen?
1 Comment
Mike.FORM
personally I use pick line the most but I don't think it should default to that.
Also if you draw things consecutively the line draw type stays the same.
You only need to select it once when starting.
