Rebar Bending Details
The new feature of Rebar Bending Detail is a great update for structural engineers, but has a great lack for everyone who uses assemblies (ex. Precast designers), you cannot use it becuase we are not allowed to use Rebar Bending Details on a assembly view. You can only use this feature on a Model view (See attached images).
Would be great to have an update of this, so we can use it on assemblies views too.
Hope Autodesk will give a look into this.
Thanks!
2 Comments
This post was solved by @ovidiu_paunescu on the Revit Structure Forum
"With the assembly view open, you can start the bending detail command from Annotate tab > Symbol panel > Rebar Bending Detail and select the rebar in the assembly to create the bending details."
https://forums.autodesk.com/t5/revit-structure-forum/rebar-bending-details-rvt-2024/m-p/11874775/hig...
peticid
As Bogdan mentioned in the previous post, this is already possible in Revit 2024.
