Show only
Search instead for
tag a structural beam....the tag can be aligned horizontally, vertically and by model
now tag a wall, or a structural column etc. (most of the tags,sadly) there you can only choose between horizontally and vertically...the "by model" option is completely missing in most of the tags unfortunately
the "idea" (not really an idea but a basic feature) is to allow every tag to be aligned to the model geometrie
I think it would be a nice addition to be able to use the "Rotate with component" option and tie it to a parameter. Instance would be best, but Type would even work. Either would be better than what we currently have to work with.
I just created an idea for that option. If this link doesn't work, just look for one named "Allow tags rotate with component as an instance". (For some reason my links never work when I copy/paste them from the Idea page).
This idea has been created on the behalf of an user.
The idea would be to enable to possibility to annotate elements by being able to choose text orientation.
Currently, when beams or walls for instance are inclined (not strictly vertical or horizontal, for instance +45° or -45°) text is oriented depending on the element’s orientation (assuming that the option “Rotate with component” has been activated in the family parameters).
The orientation of the text is then different.
What is expected is enabling the possibility to select text orientation so the user can choose to have a consistent text orientation in the sheets he / she creates.
allow (post-creation) free-rotation of tags (override 'Align with Element')
Tags and Text Part 8 - Allow Tag Rotation - Keep default behavior as-is, but allow for post-creation rotation (using the rotate tool) of all tags on an as-needed basis (so "Align with Element" only governs until "overidden" by the Rotate command)
Free rotation of tag - It would be great if column tag could be rotate free by the user, (not just hor. or vert.). Now i have to make a new family and set the angle in it.
tags rotation - allow rotation for tags & annotations; not only horizontal & vertical and there is no other options; I don't want to create anther families with different angles
Tags that can be free rotated [but maybe next idea would satisfy OP's needs] - It would be great to rotate tags with all categories as same as generic annotations. According to our standards, tex tags should be parallel to the element
With Revit 2021, the "Rotate with component" checkbox in families now works for many categories, including Structural Foundation Tags, however, it only works for tagging Isolated Foundations, not Wall Foundations. Please make Structural Foundation Tags rotate with component for Wall Foundations too.
