Dimension to snap points
It would be useful to allow dimensioning to all the snapping points of elements, like endpoints, midpoints, nearest, perpendicular and intersections etc.. It would save me a lot of hassle from drawing detail lines just to dimension to a particular point which doesn't update itself when the elements are amended.
7 Comments
Obviously, the possibility to snap an dimension to an line or object for placing it.
Tags (3)
adper27
Snapping a dimension line to the midpoint of an elements. For example two columns in between is a beam can measure the midpoint of a beam.
dplumb_BWBR
anielson
Right now you can snap to the middle of a line but not dimension to that point.
Often, circles are 2 arcs and you can only dimension to their endpoints. Please add middle points as a snap on arcs, and give us the ability to dimension to that point as well!
See this discussion on AUGI for proof of a general desire for this feature.
https://www.augi.com/forums/showthread.php?164293-dimension-to-midpoint-of-detail-line
Here is a similar Idea. I can merge the Ideas and Kudos if you like!
Dimension to midpoint of detail line or elements - Autodesk Community
guyMQ3ZE
This is a fantastic idea. It would save a lot of time in complex architectural models, where we are often drawing very short detail lines in order to dimension to the correct point.
If this option is implemented, it should be possible to turn it on / off, so that snap point dimensions don’t get in the way when we don’t need them. Maybe have a Instance parameter for Dimensions: “Dimension to Snaps” checkbox.
tphillips
Agree, this is a fantastic idea. Also to include the "center" of all circular items, including holes and round objects in families.
